I'm finally getting round to sorting water ingress, and the main area I've found is the front driver window letting water in. I've got the carpets up, door cards off and can see water is coming in from what I think is the lower window seal.
At the moment I've got the window motor removed, could that be causing this by not pushing/holding the window right?
Or more likely the window seals aren't sealing fully and have lost their spring so not sealing the leak?
Any suggestions.
In the image you can see water is coming from the inside of the door, this is whilst I was spraying the window with water, so that's definitely the problem.
Thanks in advance on tips/suggestions as always
Andy
