Sure enough, it's the boot seal that's leaking, right around the wiring that leads into the boot.
Mine looks like it's been "fixed" or altered before as there is no rubber cover for the wiring, that looks long gone, so now onto the leak, even after holding wires out the way so they don't foul the rubber seal there still seems to be water leaking in.
The inside shows the wiring exposed:
And when shut the boot shows the exposed wiring in the top channel:
Pretty poor design when I look at how it works, but am I right in thinking I need to "pad" the existing seal out/replace it so it's got more push on it to create a better seal?
If so, then is replacing the seal an option (Quick search doesn't give exact replacements), and if not has anyone had any luck with 3rd party/compatible seals. I see another post/search throws up:
https://ebay.us/AnM0De
Large Car Boot Door Bonnet Rubber Edge Seal 34mm High x 13.2mm W #23
Which looks close to what I want, any opinions on it? It's sold by the metre so will go and measure and see what I need.
Otherwise, any suggestions to getting this watertight again?
Thanks!
Andy
