Has anyone else had the problem of re-spraying their front wings and then being unable to re-attach the odd "L" shape gutters that run along the underside of the bonnet from the front pillars to just above the front lights? Mine are a bit chewed up by the spay shop and after soaking them in rubber restorer they seem to be glue-proof (even after much de-greasing) - any 480 life hacks appreciated!
Tim
alternatives to standard issue 'wing gutters'
Re: alternatives to standard issue 'wing gutters'
Sandpaper the area then clean up?
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
2012 Seat Exeo ST
Its a fair shout, my old gutters were pretty brutally removed from my old wings, it looks like they are a compound of the "L" shape rubber, a thin rubber strip then the expanded rubber foam used to stick it in place. Mine are pretty de-gresed but I dont think I'll get a good grip as the gutters are partially damaged on the underside. But as you say, worth another try
All the best
![Smile :-)](./images/smilies/icon_smile.gif)
All the best
I've had a look through several of the online trim suppliers and can't fin anything that stands out as an obvious replacement.
Will do some more once I've had a proper look at mine (because I think mine aren't exactly tip-top condition
I've had a good old dig online and I'm honestly not sure, most "L" profiles are way too big and our gutters are nearer a 50' angle than an 90'- keep me posted if you find anything ![Smile :-)](./images/smilies/icon_smile.gif)
T
T
