ABS Fault Problem
melon118
ABS Fault Problem
Post by melon118 » Sun Jun 09, 2019 7:59 am
Hi,
Unfortunately, I have problem with ABS, too :/
I think, I have MKI or MKII version, because I don't have diagnostic box
My car doesn't have braking servo, so everything working on ABS pump
One year ago pump stoped working and fault icons ( (ABS) and (!) ) lights up
I try to check fault codes by connect pins in diagnostic port but i didn't see anything on dashboard
Pump is working, I connected it with jumper in relay box and it starts
I tryed to change relays, but still nothing
ABS sensors? Everyone have 1056-1100 ohm's
I don't have any idea what can i do more
i'm start thinking that the ABS control unit is fault, but i don't know how i can check it.
Pleas for yours help
Under this link are photos of my ABS control unit, https://photos.app.goo.gl/98761hYLVYNf9Lvr9
Re: ABS Fault Problem
Post by jifflemon » Sun Jun 09, 2019 10:07 pm
I sense a teves Mk2 unit, which would probably mean a dead accumulator
Look for Jaguar Classic Parts, part number JLM 1907. https://www.jaguarclassicparts.com/uk/part/JLM1907
Post by brinkie » Tue Jun 11, 2019 7:51 am
When ((ABS)) and ((!)) are lighting up at the same time, it is most definitely a faulty accumulator. The scary part: in an ATE MkII system not the inlet vacuum but the accumulator provides pressure for the brake booster. So you are not only losing ABS, but brake boost as well...
balto8
Post by balto8 » Tue Jun 11, 2019 7:34 pm
Much cheaper replacement
https://www.ebay.es/itm/New-4630A011-AB ... 2958924055
To make sure it fits ask the seller for the size of the thread. It should be metric 13 (M13). Also not sure if this one works with the same range of pressure, but definitely worth asking. I have to buy one. One of these days...
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
melon118
Post by melon118 » Thu Jun 13, 2019 10:37 am
Great, thank you for your answers😊
Can I check it before i buy it?
balto8
Post by balto8 » Thu Jun 13, 2019 12:44 pm
I have bought one yesterday. So let me try it and see if I works. Should be coming from China sometime in July, maybe sooner
2012 Seat Exeo ST
melon118
Post by melon118 » Fri Jun 14, 2019 10:44 am
Ok, but can I and how i can check this part before i will change it?
melon118
Post by melon118 » Thu Sep 05, 2019 11:31 am
Hi,
balto8 did you receive ABS accumulator? Is it works?
nicklee
Post by nicklee » Thu Sep 12, 2019 11:38 am
unless you get confirmation that another accumulator fits, then go with the part from Jaguar. It's expensive but it's a Teves part made in Germany - at least the one i got from them was - and it works perfectly. They should last around 8 years so if you intend on keeping the car it's not a bad investment really.
here's a guide: viewtopic.php?f=14&t=35151&p=209649&hil ... k2#p209649
and here's a video of someone diagnosing the problem on an old Ford with the same Teves unit. The car's different but the principle and warning light sequence are the same: https://www.youtube.com/watch?v=ACCxUxKkryg
there has been some discussion of getting the old accumulators re-pressurised, and apparently there are a few places in the UK that will do it, but i'm not sure about the results of that.
good luck with whatever you choose to do...
1992 Paris Blue 480 ES
