1.7 turbo MAP sensor, where is it?
shaun_469
Post by shaun_469 » Sat Mar 16, 2019 12:06 pm
Hi everyone, I’m probably being blind, but I can’t seem to find my MAP sensor...can someone point me in the right direction please!
Thanks in advance! Shaun
Re: 1.7 turbo MAP sensor, where is it?
Post by MisterH » Sat Mar 16, 2019 12:11 pm
I think it is next to the fuse box on my '88 car, and is definitely in that section of the engine bay.
Hope this helps!
Current Jobs to do (17/08/19):
Fix Speedometer
New Tires
Fix Radio/Cassette
Post by jamescarruthers » Sat Mar 16, 2019 1:27 pm
Not blind! The Turbo set up doesn't have one and instead has a MAF (Mass Air Flow) meter
shaun_469
Post by shaun_469 » Sat Mar 16, 2019 4:58 pm
Cheers for the replies guys, will have a look later, I’m sure I’ve seen it had one, and I’m also sure it’s listed on eurocarparts as a spare....will have a look anyway!
Robou
Post by Robou » Sat Mar 16, 2019 11:00 pm
Don't cheer too early, it's inside the ECU EZ210K. Next questions: Location? Under the upholstry at your left leg. How's that? Sitting in the drivers seat.
Too old to bother
480 Turbo midst '91
shaun_469
Post by shaun_469 » Sun Mar 17, 2019 1:37 pm
Sounding like a big job :D only wanted to try it on a different car I have, they apparently share the same map sensor and the other car is playing up...is it removeable from the ecu??
