URGENT: need throttle brass screw
gsa60
Post by gsa60 » Sun Jan 13, 2019 3:57 pm
Hi,
I need urgently the theottle brass screw that adjusts the idle. It's for a 91 turbo.
Anyone has one that can sell?
Re: URGENT: need throttle brass screw
Post by jamescarruthers » Sun Jan 13, 2019 7:57 pm
Part number is 3344818 (no longer available, surprise, surprise)‎. Parts book has this used on the 2.0 cars too so that should widen your search a bit.
1987 Volvo 480 ES, 507274, 217 - Red
1992 Renault Master Mk. 1. Machzone Chateau camper. 2.0 LPG
J449 MNL -- ES
H858 FGV -- Turbo
Post by Alan 480 » Mon Jan 14, 2019 12:47 pm
Hi,
Do you know the thread pattern? it is likely metric ?
or which one is it on the two litre and i can have a quick look if that helps then but a box of twenty from Screwfix :-)
480 ES 2litre, C30 1.8ES, SS1 + more
Post by jamescarruthers » Mon Jan 14, 2019 1:09 pm
Turbo, item 3:‎
B20, item 3
‎[url=https://postimg.cc/TKTCNHpk]Image
J449 MNL -- ES
H858 FGV -- Turbo
Post by Alan 480 » Tue Jan 15, 2019 12:38 pm
cheers
might be the week-end cos it's dark when i get home and car is outside, and don't fancy dropping the ruddy thing then having to explain to SWAMBO why the car is 'off the road' ;)
malkontent
Post by malkontent » Wed Jan 16, 2019 9:55 am
Hi
Maybe I can help you , have 1.7 Turbo and 2.0 engines for spares .
Marek
Robou
Post by Robou » Wed Jan 16, 2019 11:13 pm
If this #3 is indeed the screw you're worried about, just use anything to plug the hole. There's no use for it. Let alone for adjusting idle.
Too old to bother
480 Turbo midst '91
Post by Alan 480 » Sat Jan 19, 2019 7:51 pm
Given this post are you still needing a blanking screw? I got sort of distracted today with drive shaft issues :(
gsa60
Post by gsa60 » Sun Jan 20, 2019 2:28 pm
Yep, PM sent
gsa60
Post by gsa60 » Sun Jan 20, 2019 4:58 pm
BTW,
Robou: pluging the hole from the outside (and not between the manifold and the intake pipe) a high reving engine. Pluging the hole between the intake manifold and the intake pipe, leads to low idle.
Post by Alan 480 » Mon Jan 21, 2019 9:11 pm
Yep, PM sent
well I had a look this evening (under flood light, so not as good as day light) and I can't see any screw that is on the back of the throttle body pointing forward!!!
there is a small 'item' that is covered with a plastic fitting and an aluminium 'clip' but it is maybe a throttle stop (I THINK) but it runs from left ot right :?
the screw (if it is a screw ) might be threaded in from the engine side and goes towards the air filter
Gmac34
Post by Gmac34 » Tue Jan 29, 2019 2:36 pm
I lost my idle screw this summer, turns out it's the same as in a Porsche 944
Porsche code is 951.110.919.00
https://www.paragon-products.com/Idle-S ... 919.00.htm
Post by jamescarruthers » Tue Jan 29, 2019 2:45 pm
I lost my idle screw this summer, turns out it's the same as in Porsche 944
Brilliant!
J449 MNL -- ES
H858 FGV -- Turbo
Gmac34
Post by Gmac34 » Tue Jan 29, 2019 2:50 pm
the original Volvo one that I found after a while on the side of the road... Image
I replaced with a new one anyway as I wasn't able to find a correct size O-ring and the old one was the reason it was loose in the first place.
BTW I think this indeed has an effect on the idle, The ICV is making the fine work of course, but I think it is still good to follow this procedure:
viewtopic.php?t=19073
Check the idle speed and adjust the basic setting
Move the idle speed regulating valve to the basic setting by earthing the cable* in the test point near the crankcase ventilation.
*B18F: brown/green; B18FT: brown/grey.
-Switch off the airconditioning and wait until the thermostat is fully open and the cooling fan has switched itself off.
-The idle speed should then be 11.7 r/s (700 r/min); adjust, if necessary, with the adjusting screw on the front of the TB. (brassy - gold colour)
-Remove the earth connection from the test point.
-The idle speed should then increase to 13.3 r/s (800 +-25 r/min).
In my understanding, it lets the ICV work in the correct range and it made quite a difference (for the better) to do it this way instead of just screwign it in all the way, mostly noticeable while parking as the engine revs would not dip down that much
