1988 Volvo 480 ES - A New Era Dawns
Re: 1988 Volvo 480 ES - A New Era Dawns
Post by brinkie » Tue Nov 26, 2019 10:52 am
Jaster wrote:
Thu Oct 24, 2019 7:38 pm
One other interesting thing I found while plugging part numbers into Google was this rear wiper motor, apparently used on the 740, 760 940, 960 and V90:
Look familiar? Mechanically it looks identical and presumably it works on the same principle internally since the wiper goes back and forth in the same way, but the pinout is somewhat different so some R&D might be required, equally might turn out to be a dead end. Also no manual winding knob so less ideal for pop-ups, but might be a source of parts to rebuild our motors in the future purely based on the assumption that there will be more of these around in the wild (at least in the UK).
Well, it looks interesting, and maybe it fits without much trouble, but it will definitely not work the way you want a popup motor to work, because there is only one resting position for wipers and a popup headlight needs two positions. In other words, the popup headlight will open... and close right away!
What could work, is taking the large nylon cog from the rear wiper mechanism and transplant that in a popup motor (assuming they have the same size), and of course, the motor itself. But it does lack an "up" position, it is intended to make a sweep across the rear window and return to the resting position.
Murf
Post by Murf » Tue Nov 26, 2019 11:11 pm
The pop up motor in the 480 is also shared with a model of Ferrari so if we ever run out we can keep an eye out for them in the local scrapyard 😁
Edit: it's a 456 😁
https://www.ferrarichat.com/forum/threa ... or.556429/
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
