aircon drive belt
JimAitken
aircon drive belt
Post by JimAitken » Mon Sep 26, 2016 8:30 am
Sounds like my aircon unit has shattered inside... lots of rattling noises like there's something broken being thrown around. Sounds dreadful. Can I simply remove the AC drive belt to disable it? And is it an easy job to remove belt? :cryhard:
current: 480GT, V70 D5
previous: 480Turbo, 440, 850, V70 Classic. Renaults 4/5/6/20, Mini Cooper S (1968), Alfasud ti
Re: aircon drive belt
Post by Alan 480 » Mon Sep 26, 2016 11:51 am
easy to remove, YES, stanley knife :wink:
although it means you can't re-fit in future . . . . . . .
will it affect anything else, that depends on what else it drives
JimAitken
Post by JimAitken » Tue Sep 27, 2016 1:52 pm
Alan 480 wrote:easy to remove, YES, stanley knife :wink:
Thanks for the tip Alan... problem solved. I had a look to see what was on the same belt and discovered the belt was shredded and the rattling noise was coming from the shreds slapping everything down there. Cut off the shreds and it's now nice a quiet again, so now looking for replacement belts.... cheaper than a new compressor!! What a relief... didn't look forward to replacing that. :hopping:
thanks again
Jim
balto8
Post by balto8 » Tue Sep 27, 2016 3:13 pm
Done that a couple of weeks ago. Easy one.
Need to loosen the alternator tensor so it lowers a few cms, and you can replace it. Can be fully done from above.
600mm 3 channel belt.
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
JimAitken
Post by JimAitken » Tue Sep 27, 2016 4:32 pm
balto8 wrote:Done that a couple of weeks ago. Easy one.
Thanks... will change both belts at the same time. Where did you source your belt?
balto8
Post by balto8 » Tue Sep 27, 2016 6:53 pm
Any parts shop will have it or be able to have it under request.
2012 Seat Exeo ST
ormolu
Post by ormolu » Sat Oct 01, 2016 2:17 pm
I recently replaced the aircon drive belt on my 480 Celebration. The best way to access it is via the driver side front wheel arch.
I removed a Hutchinson belt marked 4K582 and replaced it with a Gates belt marked 4PK580. This indicates a belt with 4 peaks and an overall length of 580mm. The length is not that critical, so anything between 580 and 600 would do.
(4 peaks = 3 channels between the peaks).
Barrie Jones
Current 480: 1995 Celebration 2.0 Burgundy
Previous: 1994 Celebration (rear-ended by a Transit van)
1993: Black 480ES 1.7 (sold)
1990-92: Bright Red 480 Turbo (Company Car)
JimAitken
Post by JimAitken » Sat Oct 01, 2016 4:23 pm
ormolu wrote:I recently replaced the aircon drive belt on my 480 Celebration. The best way to access it is via the driver side front wheel arch.
Thanks for that tip. I couldn't work out how to get the belts replaced without bruised knuckles. Didn't think of tackling it via the wheelarch!
cheers
Jim
Baxter
Post by Baxter » Sun Oct 02, 2016 7:35 pm
And take care not tighten the belt too much or you'll damage the alternator bearing.
This happen to my car. IT's a wide belt so I don't think it's going to slide loosen it a bit.
Hector.
JimAitken
Post by JimAitken » Sun Oct 02, 2016 8:37 pm
Baxter wrote:And take care not tighten the belt too much or you'll damage the alternator bearing.
thanks for advice.
