Blinky 51/480
arthuy
Re: Blinky 51/480
Post by arthuy » Sun Nov 10, 2019 7:55 pm
I havent been able to look at the car, I did have plans to work on it this weekend but work got in the way.
I took this photo last week, you will see why I think the problem is rear spring related, hopefully I can get some time on it next weekend.
arthuy
Re: Blinky 51/480
Post by arthuy » Sun Nov 10, 2019 8:20 pm
This was the rear springs when I swapped them.
They do look longer, I put that down to the old ones being old and weak.
Monroe SP531 i think they were. Will do some cross referencing and see if I can find the specs.
Re: Blinky 51/480
Post by jamescarruthers » Sun Nov 10, 2019 9:41 pm
This is interesting. Mine is on Monroe rear springs too and looks like it is on stilts. Also the composite rear bumper bar doesn't help.
Re: Blinky 51/480
Post by jifflemon » Sun Nov 10, 2019 10:21 pm
We sure they're the right springs?
The first hit on google shows them fitting a Ford Focus Hatchback 1.6 16V (1998 - 00)
Re: Blinky 51/480
Post by jamescarruthers » Sun Nov 10, 2019 10:56 pm
I got 'em from Mister Auto, SP0531
Re: Blinky 51/480
Post by jifflemon » Mon Nov 11, 2019 9:22 am
Doh! Copy/paste error - Searched the wrong part number!
480 Expert
Re: Blinky 51/480
Post by dcwalker » Mon Nov 11, 2019 9:23 am
Even allowing for compression with age, the new ones look significantly longer...
Sorry if you have already said this somewhere, but what is the situation with your front springs? Are they the originals or replaced? I appreciate they are all part of the whole strut with the shock absorber so a different set up to the rear, but I was just wondering whether your problem is being down at the front rather than up at the back?
I was just thinking that people lower 480s by up to 40 mm sometimes to make them sit lower on the arches, because there is - by design - a bigger gap above the wheels than would perhaps look ideal. Hmmm...ignoring the angle of the car I still think your rear end looks too high, but perhaps the effect is being accentuated a bit? Mind you, achieve the same at the front and it'll be as James says his is - on stilts!
Not sure... :?
Current: 1994 480 GT, 1995 480 Celebration 467/480 (plus 2004 C70 Collection, 2014 V60 SE Lux Nav)
480 Expert
Re: Blinky 51/480
Post by dcwalker » Mon Nov 11, 2019 9:26 am
Further rambling thought - are these new springs generic for the 440/460/480? If so the ride height on the 440/460 was a tad higher...
I will need to check when I can, but regardless of variations in original spring sizes across the 480 range, I am pretty sure they were in any event not the same as the 440/460.
Unfortunately these days many of the aftermarket spares are just produced across the whole 400 range, usually to the disadvantage of the 480!
Re: Blinky 51/480
Post by jamescarruthers » Mon Nov 11, 2019 12:47 pm
Yes, mine does look wrong. I still have the original springs and might pop them in when I get the car back
Re: Blinky 51/480
Post by jifflemon » Mon Nov 11, 2019 3:14 pm
You can see the difference in ride height here:
Std on the left, -40mm on the right.
Re: Blinky 51/480
Post by Alan 480 » Mon Nov 11, 2019 6:36 pm
Jeff
nope , photo is not displaying, linky wrong :-(
arthuy
Re: Blinky 51/480
Post by arthuy » Tue Nov 12, 2019 7:43 pm
new springs and shocks all round.
I will put the original rears on and see how it looks.
