cracked instrument casing problem solved..
rhigga
Post by rhigga » Fri Apr 08, 2016 4:30 pm
There i was cleaning the dash when that annoying corner crack completely broke free.... :angry:
After a great deal of thought, i concluded the only way to fix the problem was to introduce a faux leather trim to hide it altogether..
So I sent off for some 20mm leather tape and adhered some very strong 19mm double sided adhesive tape to back....seems to have worked. :hopping:
1992 480 Turbo Auto with richmod
Re: cracked instrument casing problem solved..
Post by Alan 480 » Fri Apr 08, 2016 7:21 pm
That's a neat solution a sour surround is getting the same way, but also there are precious few fixings left, most are stripped or the plastic around them has fallen apart with age :-(
any particular web-site for the sticky/fake leather stuff, & which sticky tape, as loads out there!
rhigga
Post by rhigga » Fri Apr 08, 2016 7:51 pm
Sure,The faux leather was from eBay item number:261638722332 and the double sided tape was from B & Q. There are 2 types, 1 Blue and 1 Red,the red being the extra strong one.
The only fly in the ointment is the tape is white so i had to use a black ink marker just on the edges while still rolled up before applying and thats it....good luck..
