Where can i find a set of bushes for the rear end ?
I hear you guys are mostly happy about the 480 handling but it is not so with mine. she looses her grip from the rear sometimes and leans a lot in corners so im guessing that my bushes are worn.
So where can i find a complete set of bushes for all four wheels ?
it must be someone that will ship to Malta ( preferably cheap shipping costs too )
hat would be the approximate cost fo the entire set ?
try volvo dealer
also ebay has some fronts
http://cgi.ebay.co.uk/VOLVO-440-460-480 ... dZViewItem LEFT SIDE
http://cgi.ebay.co.uk/VOLVO-440-460-480 ... dZViewItem RIGHT SIDE
http://cgi.ebay.co.uk/Volvo-440-460-480 ... dZViewItem State what side you want
Trust me mate, YOU WILL need new front wish bone bushes (auto and manual wishbones are not the same!)
also try www.eurocarparts.com and www.gsfcarparts.com
I have looked through the parts manual and found the following related to suspension and bushes:
Section 61 - Subframe With Front Suspension
No.3 - 3485813-4 - Rubber Cushion - 2pcs.
No.4 - 3467815-1 - Rubber Cushion - 2pcs.
No.7 - 3411810-9 - Rubber Bushing - 4pcs.
No.28 - 3120869-7 - Bushing - 4pcs.
Section 65 - Rear Suspension
No.8 - 3461788-6 - Bushing - 2pcs.
N0.25 - 3441235-3 - Torque Rod - 2pcs.
Section 72 - Front Suspension
No.18 - 3467713-8 - LH Stay - 1pcs.
No.18 - 3467714-6 - RH Stay - 1pcs.
No.20 - 3432811-2 - Rubber Cushion - 2pcs.
No.21 - 3432662-9 - Bushing - 2pcs.
Section 72 - Rear Suspension
No.12 - 3411804-2 - Bushing - 2pcs.
No.13 - 3411805-9 - Bushing - 2pcs.
No.17 - 3432009-3 - Rubber Cushion - 2pcs.
Did I miss anything?
Am i going to need all of these, or are some of them not generally required ?
If not all of the above is required which will i need ?
Any help will be greatly appreciated.
- VanDerGraaf
Just buy it all if you can afford to!
Previously:
'97 Saab 9000 Aero gone
Grey '88 ES dead
Previously:
Grey '88 ES dead
- VanDerGraaf
I don't know if you will at all- that's just a lot of part numbers but no real descriptions of the parts.
I would take Martins advice to begin with (new shocks, front wishbone bushes, front and rear droplinks) and see how the car feels after that.
It may be enough for you, it may not.
If not, you can then go on to replacing various other bits!
Previously:
Grey '88 ES dead
Previously:
Grey '88 ES dead
i just ordered the following from https://www.partsforvolvosonline.com/default.php:
4 x 400 Series (lower arm) Bush (85.1810) = £26.76
1 x 400 Series Drop Link (Front Left Hand N/S) (85.6129) = £10.30
1 x 400 Series Drop Link (Front Right Hand O/S) (85.6130) = £10.30
1 x 400 Series Front Brake Discs (Pair) NOT VENTED (MDC732) = £24.35
1 x 400 Series with hub Rear Brake Discs (MDC733) = £35.80
1 x 400 Series Front Brake Pads (ABS) (MDB1640) = £29.43
1 x 400 series 88'-96' (Not 1.9TD) Rear Brake Pads (MDB1459) = £22.80
1 x 400 Series (Turbo)Clutch Kit (40.333) = £87.04
for a total of £312.28 including shipping to Malta
it seems like a fair price or did i overpay ?
The good thing about this seller is that he has original volvo part numbers for reference so i knew exactly what i was buying and made sure it was correct
- Agwa Moose
Rear linkrods only @ dealers. Rest can be ordered from ScanTechAmonra wrote:so now im gonna need the rear linkrods, panrod & torquerod bushes right ?
-'87 480 ES red
-'87 480 ES red
Not so sure, as they are producers. I think that on partsforvolvo.com they have scantech products so ask them if they can have more parts.Amonra wrote:
How do i order from scantech ?
-'87 480 ES red
-'87 480 ES red
www.partsforvolvo.com does not work
I meant www.partsforvolvosonline.comAmonra wrote:www.partsforvolvo.com does not work
-'87 480 ES red
-'87 480 ES red
