Errrrm caliper adjuster???
Went to undo the 5mm allen head thing and what apeared to be oil started to pour out so tightened it again. Any ideas? Might just be water I suppose?????
John
John
Citroen 2CV, lowered on 12" Wooden wheels, performance 1cm exhaust, stabilisers & chemical toilet in drivers seat
94 480 Turbo - now the missus's car!
Judas's car!! - 292BHP Celica GT4....I couldn't help myself!!
- chris1roll
....hmmm not good! Brakes are working fine though with no visible leaks. Could it just be a leak around the adjuster itself?
I am trying to undo the right allen head bolt aren't I? I notice that there is a 7mm bolt in a rubber sleeve, under a rubber bung aswell. Whats that one for?
Now where was that thread again on fitting 240 four-pots????
John
John
- chris1roll
Thats the right one you are doing.
The ones in the rubber sleeve are for removing the caliper from the car.
The brakes will work as they are, but if the seal around there has gone, its likely the others won't last much longer, if it was me i woud change it right away, don't take chances where the brakes are concerned.
2001 V70 XC 2.5T
1989 744 GL Auto
1989 744 GL Auto
- bbf
i'd say so, but you'll also have to to flood the earea betwen adjuster and alen head sealing so there's no air in it.
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
- rpruen
This is a part of the brakes, don't take the chance that it may be ok. Change it, because if it does fail you may end up hurting yourself or someone else.
I also agree with whoever said the air in the adjuster part may get into the braking system. If you can squeze fluid in, then the air can also go the other way, it's got no where else to go (unless something else is leaking as well).
Richard
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
Hi!
Well well, you have a point there!
But the price of the calipper and the gain is not worth it, air will not return to inside the calipper, air will stay att the highest level.
It is possible to change the oring, see www.480center.com /topics / chassie /renovera bromsar (page down at moment)
/Jonas
Former car mechanic
/Jonas
Former car mechanic
Engineer
John mate!!!!!!!
oh and John,I posted about the 240 4-pots a few months back.DBS from memory informed me that due to measurements/fabricating involved it was far from viable mate!
I was pissed off too!!!!!!
and yeah the calipers?Change it big boy!!!!!!!!
I'm No Longer Here :(
- Murf
this is probably going to sound stupid but ages ago i read about a guy with a mk2 granada who wasnt impressed with his brakes (obviously, it being an old Ford!)
he rigged up a PAS pump as some sort of mega brake booster (instead of the servo) apparently the effects were amazing and still retained all the brakes feel.
anyone know about this sorta stuff and want to comment whether this would be viable??
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
Hi
Here the right link http://www.480center.com/servlet/user?a ... cle&id=317
Sorry, it´s in swedish.
Murf, your right, foor an example AUDI used the powersteering as booster for the brakes. (you get even pressure, and higer) so you inly need the valve to install it.
Catgroom, i agree, real racecars have solid brakecalippers, they dont bend when brakeing as the standard flooting one does (but these are simplier and cheeper)
/Jonas
/Jonas
Engineer
- chris1roll
Chris, if you remember my car had yellow plastic screw in caps that looked factory fitted. I assumed they changed the design as the caps own seize in. I had brake fluid leak from the adjuster on one of my rear calipers, annoying as i'd only just painted them, found a spare caliper, quick swap and bleed...job done and peace of mind.
1993 Es, turbo conversion. First ceramic coated engine running sweet. Sold! :( miss her
www.teamvolvo.co.uk
www.teamvolvo.co.uk
- chris1roll
