Brake pads
Turnipman
Brake pads
Post by Turnipman » Sun Dec 19, 2004 11:27 am
Ok this one seems like a no brainer, I need new pads on the front but the disks are fine, the disks are the solid ones not the vented ones by the way.
I would assume most people go to kwik fit, but i fell uneasy going to a place that has the name kwik in it.
Where do you guys normally go and what type of price am i expecting, pads at euro car parts are like £25 for a pair?
Vocalise you merry bunch of informaion people of great power. :wink:
dragon
Volvo 480 Club Europe CREW
Post by dragon » Sun Dec 19, 2004 11:33 am
I go to my driveway and do it myself :lol:
Gaz Wilson
Turnipman
Post by Turnipman » Sun Dec 19, 2004 11:52 am
Granted I don't have machanical mind but i am not a muppet, could this job be done easily or will i bring in the sunset tonight under my car?
:kill: cos you can
dragon
Post by dragon » Sun Dec 19, 2004 12:02 pm
Well it took me, on my first ever brake change (I'm not overly mechanical-minded either), with rusted bolts to contend with a little over 2 hours to replace my front pads AND discs -
so just pads ought to be about an hour. If you do do it, it's worth wire-brushing your calipers to get most of the rust off them before you put the new pads in, particularly the channel the pads get pushed along in by the hydrauling ram. Don't forget to open your brake fluid resovoir to allow you to push back the rams easier (still quite a hard part of the job as they are very stong)
Gaz Wilson
pol
Post by pol » Sun Dec 19, 2004 12:03 pm
It is a very easy job and probably the first thing I ever did on a car myself which got me started on everything. Even haynes manuals are good for this job. All you need is the big allen key for the caliper and you're away. The pads just clip into the caliper once its removed. It's only 2 bolts so get out there and learn!
pol
chris1roll
Post by chris1roll » Sun Dec 19, 2004 1:34 pm
Once you know exactly what your doing its a piece of piss. We changed rpruens pads in 15 mins including jacking up and down.
As Dragon said if it was discs as well, when i did front and rear discs and pads i was doing all sodding day cos of the stupid rusty bolts. (ts not just 480's though, theres a mates golf in our workshop cos he rounded off a caliper bolt)
Proper volvo front pads are only £35ish.
So go and do it yourself and save the money that you would have paid a monkeh to do it for you, and spend it on optimax or something!
2001 V70 XC 2.5T
1989 744 GL Auto
martinholmesuk
Post by martinholmesuk » Sun Dec 19, 2004 3:02 pm
Audi TT
Turnipman
Post by Turnipman » Sun Dec 19, 2004 6:36 pm
Ok so i went to halfords got the pads easy, got home jacked up and manage to get all bolts undone exept the locking bolt. You all know what kind of shape it is, so the outer ring completly snapped off, not my day it seems.
While i am at work tomorrow my dad says he will try heating up and cooling it down see if that does it.
But if doesn't, any ideas of how to get it off.
chris1roll
Post by chris1roll » Sun Dec 19, 2004 7:33 pm
youve got me a bit confused by that:
1) loosen wheel bolts
2) Jack up
3) take the wheel off
4) remove the metal spring.
5) using two 13mm(iirc) spanners, loosen the upper caliper bolt
6) remove hte lower caliper bolt
7) swing up the caliper,
8) remove old pads
and then put back together.
ignore the arrow, see where the tools are, these (and the same at the top)are the only bolts you need to touch to do the pads. Are you having trouble with these?
2001 V70 XC 2.5T
1989 744 GL Auto
chris1roll
Post by chris1roll » Sun Dec 19, 2004 7:43 pm
Xtra hint, use a pair of plumbers grips to push the caliper back in with. make sure it goes in straight else it will be a pain, you may have to squeeze on one side then the other, you'll know what i mean when you do it.
2001 V70 XC 2.5T
1989 744 GL Auto
deviliShred480
Post by deviliShred480 » Sun Dec 19, 2004 9:54 pm
abc
Last edited by deviliShred480 on Wed Aug 03, 2005 5:32 pm, edited 1 time in total.
pol
Post by pol » Sun Dec 19, 2004 10:44 pm
I don't know what locking nut you could mean?
pol
chris1roll
Post by chris1roll » Sun Dec 19, 2004 11:02 pm
Try a piece of wood across the piston and lever roughly in the middle to push it back evenly. Another trick is to place a socket in the recess of the piston and push on that to put the force in the center of the piston.
Hate to try to teach someone how to suck eggs but sometimes we get set in our ways and don't always go looking for alternative solutions, and also I thought it was also the idea of the forum to exchange ideas.
Thatas a better idea actually.
I shall try that next time, sure mine are coming up for renewal, done about 10 thousand miles with these :shock: grooved discs shred them!
2001 V70 XC 2.5T
1989 744 GL Auto
Murf
Post by Murf » Sun Dec 19, 2004 11:33 pm
are the front ones the same as the back where you have to wind back the auto adjuster bolts? or do you just push the piston in with a g-clamp?
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
JohnTurbo
Post by JohnTurbo » Mon Dec 20, 2004 12:11 am
G clamp the fronts, wind in the rears. G clamp is the best way by far, but not everyone has a g-clamp that big. Luckily i do :)
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
