Brake pads
Brake pads
Ok this one seems like a no brainer, I need new pads on the front but the disks are fine, the disks are the solid ones not the vented ones by the way.
I would assume most people go to kwik fit, but i fell uneasy going to a place that has the name kwik in it.
Where do you guys normally go and what type of price am i expecting, pads at euro car parts are like £25 for a pair?
Vocalise you merry bunch of informaion people of great power.
- dragon
- Volvo 480 Club Europe CREW
I go to my driveway and do it myself
Gaz Wilson
Gaz Wilson
- dragon
Well it took me, on my first ever brake change (I'm not overly mechanical-minded either), with rusted bolts to contend with a little over 2 hours to replace my front pads AND discs -
so just pads ought to be about an hour. If you do do it, it's worth wire-brushing your calipers to get most of the rust off them before you put the new pads in, particularly the channel the pads get pushed along in by the hydrauling ram. Don't forget to open your brake fluid resovoir to allow you to push back the rams easier (still quite a hard part of the job as they are very stong)
Gaz Wilson
Gaz Wilson
It is a very easy job and probably the first thing I ever did on a car myself which got me started on everything. Even haynes manuals are good for this job. All you need is the big allen key for the caliper and you're away. The pads just clip into the caliper once its removed. It's only 2 bolts so get out there and learn!
pol
pol
- chris1roll
Once you know exactly what your doing its a piece of piss. We changed rpruens pads in 15 mins including jacking up and down.
As Dragon said if it was discs as well, when i did front and rear discs and pads i was doing all sodding day cos of the stupid rusty bolts. (ts not just 480's though, theres a mates golf in our workshop cos he rounded off a caliper bolt)
Proper volvo front pads are only £35ish.
So go and do it yourself and save the money that you would have paid a monkeh to do it for you, and spend it on optimax or something!
2001 V70 XC 2.5T
1989 744 GL Auto
1989 744 GL Auto
- martinholmesuk
Look at http://volvo480.northernscum.org.uk/for ... php?t=4805 for lots of info.
Audi TT
Audi TT
Ok so i went to halfords got the pads easy, got home jacked up and manage to get all bolts undone exept the locking bolt. You all know what kind of shape it is, so the outer ring completly snapped off, not my day it seems.
While i am at work tomorrow my dad says he will try heating up and cooling it down see if that does it.
But if doesn't, any ideas of how to get it off.
- chris1roll
youve got me a bit confused by that:exept the locking bolt. You all know what kind of shape it is, so the outer ring completly snapped off
1) loosen wheel bolts
2) Jack up
3) take the wheel off
4) remove the metal spring.
5) using two 13mm(iirc) spanners, loosen the upper caliper bolt
6) remove hte lower caliper bolt
7) swing up the caliper,
remove old pads
and then put back together.
ignore the arrow, see where the tools are, these (and the same at the top)are the only bolts you need to touch to do the pads. Are you having trouble with these?
2001 V70 XC 2.5T
1989 744 GL Auto
1989 744 GL Auto
- chris1roll
- chris1roll
Thatas a better idea actually.Try a piece of wood across the piston and lever roughly in the middle to push it back evenly. Another trick is to place a socket in the recess of the piston and push on that to put the force in the center of the piston.
Hate to try to teach someone how to suck eggs but sometimes we get set in our ways and don't always go looking for alternative solutions, and also I thought it was also the idea of the forum to exchange ideas.
I shall try that next time, sure mine are coming up for renewal, done about 10 thousand miles with these grooved discs shred them!
2001 V70 XC 2.5T
1989 744 GL Auto
1989 744 GL Auto
