Wanted: seat belt holder, window regulators, temperature sensor (water) and rear tail lights
Time to get to work fixing the 480 up I reckon...
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Re: Wanted: seat belt holder, window regulators, temperature sensor (water) and rear tail lights
To add to this, the right DRL has a crack on it
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Tails lights from the french car club. Its the only serious solution
Seat belt holder? The pop out ones? Which side?
There's 2 temp sensors (one for the gauge, one for the ecu), also which engine?
Window regulators - There is a repair kit you can 3d print
The right hand seat belt holder and the sensor for the gauge. It's the 2 litre engine
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
There is a drivers side seatbelt holder up for auction on ebay at the moment.
Thanks but it's the bit at the end of the holder I need and it appears to be missingdragonflyjewels wrote: ↑Wed Aug 24, 2022 7:17 pmThere is a drivers side seatbelt holder up for auction on ebay at the moment.
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
If the bottom part is missing, check your top section to see if the connecting lug is intact. That's what usually breaks, hence the top sections were supplied by Volvo without the bottom part. Usually that's left loose but still threaded on the belt.
The missing piece is the bar that holds the seatbelt indragonflyjewels wrote: ↑Thu Aug 25, 2022 7:28 amIf the bottom part is missing, check your top section to see if the connecting lug is intact. That's what usually breaks, hence the top sections were supplied by Volvo without the bottom part. Usually that's left loose but still threaded on the belt.
https://imgur.com/a/U5SLFNr
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
You lucky b*****d!GCooper wrote: ↑Thu Aug 25, 2022 1:24 pmThe missing piece is the bar that holds the seatbelt indragonflyjewels wrote: ↑Thu Aug 25, 2022 7:28 amIf the bottom part is missing, check your top section to see if the connecting lug is intact. That's what usually breaks, hence the top sections were supplied by Volvo without the bottom part. Usually that's left loose but still threaded on the belt.
aha, so all that's missing is the roller. Just so happens I have a spare - pm me your address and it's yours
Tail lights and seat belt holder acquired... Can anyone help with windows regulators, temperature sensors (X2?)
High priority: indicator stalk, cooling fan switch
Maybe needed: b18 edit: B20 engine
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
- Themasteryeti
1973 vw beetle
1993 480s
1993 480s
Thanks! Already bought the drl lenses and tail lights from him though
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Confused - you have a GT, why do you want a B18 engine? It's a B20F in a GT.....
Of course I'm very tired
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
I have the fan switch and the indicator stalk. NB They’re both from an early 480 (‘87 ES) so the switch is for heating only, with the ‘off’ position. Switch is available now but you’ll have to let me know if you want the indicator stalk, it may be a couple of days before I can remove it.
Current: ‘95 Celebration
First love, from new, (now donor car): ‘87 480 ES
Ah I see the confusion, the switch I need is that one that turns the radiator fan on when the coolant gets too hot, at the moment the fan is disconnected because the radiator fan was stuck constantly and drained the battery.Oscar WS wrote: ↑Thu May 04, 2023 4:08 pmI have the fan switch and the indicator stalk. NB They’re both from an early 480 (‘87 ES) so the switch is for heating only, with the ‘off’ position. Switch is available now but you’ll have to let me know if you want the indicator stalk, it may be a couple of days before I can remove it.
As for the indicator stalk, yes please! The indicators stopped working but the hazards still work and a quick Google suggested a new stalk would help.
Thanks.
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
OK, buddy. Give me a day or two to get the stalk off (I’ve got a dodgy back, poor old bugger ) I’ll pm you when I’ve got it, to get your postal details etc. Cheers for now.
‘Stalk’ now available. I have dropped you a PM.
I’ve sent you another PM about your delivery, Gabriel. I did try via the email you gave me but it got bounced back. Best. Oscar
