Volvo K 6683 instrument cluster
Zvonac
Post by Zvonac » Thu Apr 06, 2023 8:02 pm
Hi guys !
If anyone have cluster K6683 in working condotion to sell, please send me PM
I have very big problems with my odimeter and speedo.
I tryed everything but my speedo is working on the moments and show correct speed and in next moment it,s dead. If i drive my car on 3000rpm speedo starts to work. It,s working in nex approx 5-10 sec and when i deacrease rpm it stops to work. This thing have effect on my engine. My car have problems with ler gas when speedo isnt working.
If you have only km/h and odimeter section it will be ok.
Thanks!
WRDendy
Re: Volvo K 6683 instrument cluster
Post by WRDendy » Fri Apr 07, 2023 8:40 am
Welcome - have you found these two threads yet:
Instrument Cluster Repair: viewtopic.php?f=24&t=35684
Speedo Cable Repair: viewtopic.php?f=24&t=35515
The speedo isn't particularly complex so it's highly likely to be some combination of the above. Assuming that you're in mainland Europe then Brinkie may well be able to help further.
Formerly known as 'Jaster'
Zvonac
Post by Zvonac » Fri Apr 07, 2023 9:15 pm
Hi WRD
I tryed every step and i have no progression on this. My cluster has 4.85V on Km/h odo gauge and 1.5ohm on my speedo sensor which is constantly in closed circut on buzz test. I dont know where to search anymore. 😭😭 Thanks for the info!
Zvonac
Post by Zvonac » Wed Aug 09, 2023 3:40 pm
It was faulty speed sensor. I changed it and everything works fine.
Ben480
Post by Ben480 » Mon Feb 05, 2024 7:22 pm
Hello everyone!
I recently register in the forum and i don´t know if i have to create a new thread but i´m also searching for a speed sensor for my 480 ES 89´
I think the ref nº is 3413744
Does anyone know where i can find one available?
I´m from Portugal and it has been very difficult to find one here.
Post by jamescarruthers » Tue Feb 06, 2024 9:04 am
Hello everyone!
Hey. Welcome. Usually it is the wire and/or connector that needs repair, rather than a new sensor.
Ben480
Post by Ben480 » Wed Feb 07, 2024 6:49 pm
Thanks for the hint but mine is really broken
That happened when we tried to pull it off :cry:
Post by jamescarruthers » Wed Feb 07, 2024 8:21 pm
Commiserations! They are really hard to get. I suspect you will have to get a second hand one. Good luck!
Ben480
Post by Ben480 » Wed Feb 07, 2024 10:15 pm
Thank you :wink:
Do you know where i can find one?
Post by jamescarruthers » Thu Feb 08, 2024 5:06 am
I'd try asking people who are breaking the whole car. I'm not on the Facebook but there are probably some cars being broken on the UK group. My wife is a member and I am occasionally allowed a look! There is a GT being broken I think.
I think someone on this forum put an aftermarket sensor in but can't remember how it worked out
Ben480
Post by Ben480 » Fri Feb 09, 2024 6:41 pm
Ok, thank you :)
Post by Alan 480 » Fri Feb 09, 2024 7:14 pm
does this link help?
viewtopic.php?f=12&t=34956&hilit=speed+sensor
discussion about 'alternatives' and ways to measure them.....
Ben480
Post by Ben480 » Thu Feb 22, 2024 3:45 pm
Good afternoon and thank you for your replys.
Luckily i have found a used one :)
