The Wolf roams
Re: The Wolf roams
Greetings all....
Can anybody please link the 'how to' on getting the vem out as I've forgotten where it is, I've just stripped my dash and I thought it would be just two screws then it would pull out, no chance..
I've also ordered some headlight bulbs as my passenger side one is very dim, it doesn't do anything not even high beam, hopefully it's just the bulb as I swapped the relay over and it's still the same..
Many regards....
Many regards....
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
Re: The Wolf roams
The vacuum block at the rear needs to come off as well as the slider wire - Watch for the clip that WILL want to ping off and vanish down the back of the dashboard. I then undo the lower frame attachment points before wiggling it all out.
Re: The Wolf roams
Thankyou for the reply, I will have a look as I didn't see any more screws to undo, does it prise off or are there screws... I stupidly undid the screws from the mounting frame and managed to wriggle the vem half out the frame..
Regards
Regards
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
Re: The Wolf roams
Soooo, I decided to have another go at removing the vem today, stripped all the dash and got as far as removing the clip and wire on top of the unit and managed to wriggle it out, I could see two plugs then about 5 wires in a plastic sleeve also connected to the unit, I couldn't see how to remove the big wires so decided to put it back together, then disaster, I couldn't get the wire back in that adjusts the temperature and I also snapped the clip.. I routed the wire to near the steering column so it's like the old style choke, I just pull it in and out The vem is working 99% of the time, is there anyway to bypass the heater altogether as I don't need the Aircon...
Still awaiting the headlight bulbs, I just hope I don't snap the pop up lid as it sounds fun changing the bulb
Regards
Regards
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
Re: The Wolf roams
Today was the day I decided to change the bulbs that I hoped had blown, passenger side headlight and drivers side DRL...
Taking off the drivers side cluster was easy enough, one of the filaments had blown so I replaced the bulb but banged it when I was placing it back in blowing the filament I had ordered two so I grabbed the other one and placed it in carefully and replaced the cluster, its brighter when the popups are down and dims when the main headlight is on, success, sadly I noticed the passenger side one needs replacing as that is just dim..
I then moved onto the headlight with a slight worry it wasn't the bulb, I stripped the popup down and pulled the bulb and it hadn't blown, what I did notice though on one of the bulb contacts is that it was rusted, I placed the new bulb in and nothing happened, gutted.. I decided to clean the plug and thankfully the bulb came on bright.. I can now drive my car at night or in the rain
The heating works if I push the VEM but that's another battle altogether, I know it isn't ideal and hopefully in the future I can take it somewhere to someone who knows what they are doing and replace it altogether, I would pay over the odds to have it fixed...
Regards
Regards
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
Re: The Wolf roams
One other thing is the long range lights, they only work on high beam with the popup headlights down, they don't work in any other setting not even with the switch near the heated seat switch, oh well at least I've got my headlights back
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
Re: The Wolf roams
Thatβs a symptom that some contacts have died in the flasher stalk. Iβve only ever fixed this by replacing itβ one attempt at opening it up was a disaster!
Re: The Wolf roams
Ahh thanks for the tip, I think I have a spare one somewhere so I will give it a gojamescarruthers wrote: βFri Apr 01, 2022 3:23 pm
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
Re: The Wolf roams
Greetings all...
Yeah this one has been on a drive for a while now, I sort of lost heart with it because I renewed a few things underneath the car and then found out that the fixing point for the rollbar that goes through the car is rotten on the drivers side..
Engine out and welding required, something I'm not really repared to put the money up for as I can buy a decent Turbo for that price I did want to focus on the power not start messing around with bodywork... If I could do it myself obviously that would cut costs but yeah..
I replaced all the shocks, drop links, wishbones, tie rods, handbrake cables, brake discs and pads along with brand new Pirelli P1s
There is a leak on the petrol tank, when you fill it past half way it pours out! I believe the rubber seal needs replacing around the sender cap as this was loose when my mate had a look...
Finally the heating needs sorting, it's the Aircon version and the vem needs soldering/replacing, I've tried to take this out but couldn't remove the block at the back and subsequently lost the clip as it went into the dash, I just put it back together instead of smashing it up π«£
Finally, the osr brake caliper or abs sensor needs sorting as it sticks a bit wearing the brake pad quicker than the nsr caliper...
I may have a change of heart but because I can't do the work myself it's not making financial sense..
Hopefully to be continued....
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
