1994 GT - eBay.
Re: 1994 GT - eBay.
Post by MisterH » Sun Nov 29, 2020 8:03 pm
GCooper wrote:
Sun Nov 29, 2020 7:55 pm
Apparently there are only 14 left on the roads, anyone here own one of the GTs?
Probably all of them! :crazy:
Re: 1994 GT - eBay.
Post by jifflemon » Sun Nov 29, 2020 8:23 pm
There were only 14 taxed in Q2 of this year, with another 43 are on sorn.
Ideally you'd want to know the MOT status of all 57 of them, as it gives a better insight on survival.
Interestingly, there was a maximum of 353 in 1994.
Edmundpwb2
Re: 1994 GT - eBay.
Post by Edmundpwb2 » Sun Nov 29, 2020 9:05 pm
Hello GCooper
I recently joined 480GT ownership as well. Looks like a nice example you got there though. Well done.
GCooper
Re: 1994 GT - eBay.
Post by GCooper » Sun Nov 29, 2020 9:43 pm
Thanks, the only problems I can find apart from MOT advisories is a chip in the bumper and the bulb in the info center (still works but very dim)
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
Re: 1994 GT - eBay.
Post by dcwalker » Sun Nov 29, 2020 10:17 pm
Several of us - me for one (see avatar...).
Looking forward to learning more about yours!
GCooper
Re: 1994 GT - eBay.
Post by GCooper » Fri Dec 04, 2020 10:49 pm
I bought it but the clutch isn't great, any advice?
How much can I expect the cost of replacement to be including labour
'98 BMW Z3 (daily)
Re: 1994 GT - eBay.
Post by jifflemon » Fri Dec 04, 2020 11:09 pm
Check first that it IS the clutch.
Have someone press the pedal and check the bulkhead isn't flexing.
Then remove the cable and make sure it runs smoothly.
Oh, and congrats on your purchase, lets have LOTS of lovely pictures! :hopping:
Re: 1994 GT - eBay.
Post by dragonflyjewels » Fri Dec 04, 2020 11:11 pm
There are 3 Gts regularly at meets, all green. My hubby has one along with dcwalker and jaster. Ours and I think DC's are currently on sorn but definitely alive and well. It will make a nice change to have a red one join us..
Re: 1994 GT - eBay.
Post by dcwalker » Sat Dec 05, 2020 12:16 pm
Welcome now you are a fully fledged 480 owner! Looking forward to seeing pictures...
Re the clutch, in what way is it "isn't great"? If it's very hard to change gear, check cable run and bulkhead as Jeff says. Also check the clutch adjustment which is easy on these cars. If it is more that it is hard to find gears, is the gear stick floppy? That can mean new bushes needed. Also worth checking gearbox oil level and quality - low level or sludge will both make changing gear difficult.
If you rule out all that, then it probably is the clutch itself. Fairly major job, can be done DIY if you are a half decent mechanic and have tools. But a long involved job, so expensive on labour if paying a garage...
Hope that helps a bit!
Re: 1994 GT - eBay.
Post by MisterH » Sat Dec 05, 2020 1:05 pm
Congratulations GC on becoming a new owner! My 480 is my first car as well and they are very good to learn on, being powerful enough for modern traffic and everything you need, without being lairy.
In regards to what DC said on gearbox oil, I recommend that you change this as a matter of practice anyway, same with the cam belt. Bear in mind that the gearbox and engine oil is only a available from France as an Elf grade, at least for my 1.7 B18E, however I am sure someone on here can clarify that.
I look forward to seeing what adventures your wedge takes you on!
Cheers,
Ben :)
Re: 1994 GT - eBay.
Post by Alan 480 » Sat Dec 05, 2020 4:37 pm
our local motor factors had shed loads the last time I was in.... (the bottles had the correct grade marked on them, but system said otherwise, I didn't argue at a £5 a bottle )
I did offer to bulk purchase for folks, but no takers. :wink:
Re: 1994 GT - eBay.
Post by jamescarruthers » Sat Dec 05, 2020 4:55 pm
Gearbox oil must be GL4, not GL5. There is some debate on this, but to be sure play it safe with GL4. Elf also to be sure of getting the right stuff. Searching eBay for Elf Tranself NFP 75W-80 brings up 9 options in the UK for the gearbox oil, so its not difficult to get hold of at all. The Elf oil is not magic, its just difficult to make sure you get the right stuff with lots of companies (producing and/or selling) out there that lie about compatibility. Elf are a known quantity for us 480 owners.
For the engine oil, any semi-synthetic 10W40 will be fine and likely better than what the 80's engine was designed to run with. Put Castrol GTX or Magnatec in if you are feeling lux. I wouldn't waste your money putting in a fully synthetic 5W40 oil in, just change the oil yearly. Look in your owner's manual and you'll see a few grades are acceptable, dependant upon the temperature outside. In the UK 10W40 is in our temp. range; so is 15W40 but the less so so don't bother with it.
Re: 1994 GT - eBay.
Post by Alan 480 » Mon Dec 07, 2020 2:57 pm
yes I found it was bottles of GL4 'in stock' :-) i was just checking on engne oil and spotted it on the satnd, bonus.....
I guess NOS? didn't look last time i was in (needed power steering fluid for C30 as blew a pipe, I now have good spare steel flexibles if anybody needs any for C30/S40/V50 with leccy pump .... don't seem to be 'readily' available??)
phil480
Re: 1994 GT - eBay.
Post by phil480 » Mon Dec 07, 2020 11:52 pm
I think my recent purchase will have put that count up +1 (mine was SORN). I think the one you have bought popped up on eBay the same day that I picked mine up (also eBay).
Current: 480 GT 2.0 '94 in Red
Previous: 480 ES 2.0 '93 in White K464SWP -Sold in 2009. Presumed dead
