Central Locking fix
Central Locking fix
Post by MisterH » Sat Aug 17, 2019 3:09 pm
'Afternoon all
by now I have worked out that the 480 is supposed to have central locking, and now I want to go about fixing the Central Locking
When I unlock the driver's door, the red tab comes out just fine, but the passenger door's does not. both locks work fine, but the central locking feature is clearly broken. I am sure I am not alone in getting annoyed when opening the passenger door sets off the alarm because the driver's door is locked, same with the boot. I do assume this is not supposed to happen!
I have looked into this on the forum and come across 89of480 mentioning that they used contact cleaner on some components, and that they now have working CL:
89of480 wrote:
Mon Jun 04, 2018 11:24 pm
I removed the door card and unplugged each connector inside the door and sprayed each one in contact cleaner, and then attempted to spray contact cleaner and silicone spray a the locking parts, and so far, so good! I have working central locking again! I just hope this repair will last through!
this seems to be one fix, but that is on a '95 celeb, mine is an '88 ES, are there differences with the years? are there any other fixes? would this fix work on my car?
Have I even got the same problem, if so, what can I try?
New Tires
Fix Radio/Cassette
Bodywork
Re: Central Locking fix
Post by jamescarruthers » Sat Aug 17, 2019 5:46 pm
Don't kn‎ow too much about this but the central locking is activated by a switch on the driver's side lock activating an actuator on the passenger side lock. So the idea of cleaning contacts up sounds pretty sensible as a start.
Also, the central locking system is controlled by the driver's side only-- don't waste valuable time trying to work out why the passenger side will not unlock the driver's side!
Another possibility is that ‎someone has changed one of your locks for one from the wrong side and the switch or actuator is missing.
As far as I know the system was the same throughout production. I certainly can't think of any changes at all. ‎
Post by MisterH » Sat Aug 17, 2019 6:38 pm
That would make sense, as for the alarm to sound, the driver's side would have to be locked, with, say the passenger door unlocked and opened.
it would seem that the alarm system is designed for a working Central locking system, and as such it is tripped by one side opening while the other is still locked, as it must be designed on the assumption that both locks open at the same time, which is why the driver's must be unlocked first, then all the others.
phew, I hope that is clear, it might seem a bit convoluted as I was writing down my thought processes as I thought :)
New Tires
Fix Radio/Cassette
Bodywork
WalkableBuffalo
Post by WalkableBuffalo » Mon Apr 20, 2020 11:04 am
Glad to have found this thread to see how the central locking works.
Was sure I had central locking when I parked up a while ago.
But after messing with getting my drivers mirror to work the other day I had to move my car out to let my dad swap his wheels over.
The door wiring loom was left disconnected.
Parked the car up and locked each door, came back and tried to start it, was greeted by the horn blaring at my for 20 seconds.
Did it again before I took the fuse out and realised it was probably because of the lock.
I don't think anyone on my street was too happy and I'm sure they all know who it was...
Good to know how it works now 😅
-Will
1991 480 ES, 1.7, Arctic Blue
Post by MisterH » Mon Apr 20, 2020 12:27 pm
Glad its helped someone out, I still haven't got round to doing it!
New Tires
Fix Radio/Cassette
Bodywork
