Replacement Door Mirrors (including housings)
Post by Martin Mc » Fri Apr 05, 2019 6:59 pm
Hello folks,
Just wondered if anyone had experience of replacing the entire door mirror units, as mine are both somewhat shot to pieces. I did think about trying to graft on 440 /460 units, if I can't get hold of decent 480 replacements.
Alternatively, is anyone aware of a supplier for replacement covers - mine are completely gone & only held together by duct tape.
Cheers for any suggestions!
Re: Replacement Door Mirrors (including housings)
Post by dcwalker » Sat Apr 06, 2019 11:17 am
Might be able to help towards one mirror...will check later when I get back home😊. Your Celeb is red, isn't it?
All the best
Post by jifflemon » Sat Apr 06, 2019 2:18 pm
Yeah, was going to ask if they were wary or late mirrors, going to guess late?
Post by dcwalker » Sat Apr 06, 2019 5:25 pm
Late mirrors Jeff - don't forget the Celebration was the run out model in 1995...
Post by dcwalker » Sun Apr 07, 2019 5:41 pm
Hi Martin
Have now checked - I do have a spare passenger side mirror, in the correct Celebration red too, but it's not up to much I am afraid. The mirror glass is cracked (although of course that could be swapped over if your existing one is ok) and the cover has two lugs broken plus bad lacquer peel on the top. The black surround and fitting part all appear ok though.
If it will help you in any way you are welcome to it.
