Subframe mounting
Subframe mounting
Hi all does anyone have a Front subframe mounting its the one on the gearbox side
Re: Subframe mounting
sub frame to car or gearbox to sub frame?
they are still available from suppliers ,
REAR gearbox mount is NLA , regardless of what any web page says!
It’s subframe to gearbox it’s not perished can it be repaired with strong glue
Is it round or horseshoe shaped?
Round and a flat piece of steel 2 bolts secure it to subframe
This is oil filled and very difficult to get hold of. Do your homework on here with search. I'd recommend getting one second hand from a late 440/460 that is being scrapped. You won't get a new one as far as we know here
yep NLA as far as we can establishjamescarruthers wrote: ↑Fri Mar 29, 2019 10:44 amThis is oil filled and very difficult to get hold of. Do your homework on here with search. I'd recommend getting one second hand from a late 440/460 that is being scrapped. You won't get a new one as far as we know here
really need to find an alternative, either see previous thread(s), here
viewtopic.php?f=8&t=35556&p=215088&hilit=frame#p215088
Wait, you say it is a gearbox mount? As in one of the two at the front of the car?
If so, you can buy these from Poland. I would recommend replacing two at the front as a pair as these replacements are stiffer.
The front two ARE AVAILABLE: http://www.ebay.pl/itm/372489522475
There are two rear ones, only the earlier horseshoe shape one is available.
Yes think it’s the one filled with oil must of already been leaked out before I dropped the subframe
I had a front one rip. Replaced and it drives lovely now!
293must of been a horrible drive with worn clutch and this mounting gone
this threw me as I thought 'flat steel with two bolts' referred to the both bolts were at the SAME end
although why this would refer to front mount was my mis-reading it.
but anyway, if you do find the REAR mount do let us know I don't think ther eis any oil in the front one, I have a damaged one here with a missing captive bolt, scrap-yard chopped the bolt off with grinder . .. . .
viewtopic.php?f=11&t=35602&p=214644#p214644Alan 480 wrote: ↑Fri Mar 29, 2019 12:53 pmyep NLA as far as we can establishjamescarruthers wrote: ↑Fri Mar 29, 2019 10:44 amThis is oil filled and very difficult to get hold of. Do your homework on here with search. I'd recommend getting one second hand from a late 440/460 that is being scrapped. You won't get a new one as far as we know here
Still, have to try these, but if you are brave enough it might be an alternative...
looks to be 25mm too much in height, and you could ADD depth to bring up to correct dims, but not really take it away, unless the height listed is INCLUDING the threaded section? the gap beteeen the bolts could be 'adjusted'?
needs a trip to a dealer or motor factor to check REAL sizes, not those from 'tinternet' ?
On my current 480 I have the other style gearbox mounts so I will not experiment with this one. Still, you can get one for 30€ so... I think it would be worth to experiment whit it, or at least that Is what I would do if I needed one on my car. The total height should be the same as the Volvo one, the measure should include the threaded part. The measurements of the Volvo https://www.drive2.ru/l/7525464/Alan 480 wrote: ↑Wed Apr 03, 2019 7:14 pmlooks to be 25mm too much in height, and you could ADD depth to bring up to correct dims, but not really take it away, unless the height listed is INCLUDING the threaded section? the gap beteeen the bolts could be 'adjusted'?
The gap between the bolts could indeed be 'adjusted', but I would bet that it's very close.
yep worth a punt if needed a replacement, mines is 'OK' for now. . . . . . but will investigate should the need ariseGmac34 wrote: ↑Sat Apr 06, 2019 12:01 pmOn my current 480 I have the other style gearbox mounts so I will not experiment with this one. Still, you can get one for 30€ so... I think it would be worth to experiment whit it, or at least that Is what I would do if I needed one on my car. The total height should be the same as the Volvo one, the measure should include the threaded part. The measurements of the Volvo https://www.drive2.ru/l/7525464/Alan 480 wrote: ↑Wed Apr 03, 2019 7:14 pmlooks to be 25mm too much in height, and you could ADD depth to bring up to correct dims, but not really take it away, unless the height listed is INCLUDING the threaded section? the gap beteeen the bolts could be 'adjusted'?
i do need some other parts from motor factors so if in I'll ask if they happen to have said item
