sorry for being a bit lazy here, somebody just to confirm my logic (two litre)
recently car will fire up on the button , but not keep running, swapped over a couple of idle valves, no difference, needs just a wee tickle of throttle pedal to keep it running, but SWAMBO's idea of a wee tickle is an idle speed of 1500+ rpm!!
I know that the idle valve has a default opening but is it that which is used at starting ?? and then the ECU quickly swaps it around a few degrees to get the modulating postion?
I reckon it could well be the control under the throttle inlet /butterfly, or maybe the wiring to the idle valve, what should it do and I could put a volt meter onto the valve to confirm/deny.
just jury rigged a small loop of steel cable to give me a 'false' throttle stop on the main butterfly just for next few days to see if improves it any
starting but not running,
Re: starting but not running,
Could it be a MAP Sensor? I do not know much about the 2.0, but when I got my '88 car it would start and then cut out, when a new MAP Was fitted it started first time. Could that be it?
good call
I also have one of those spare and an easier swap than the throttle switch!
I remember when teh wee pipe split the car would run OK , but on throttle lift off at a roundabout it would die unless quick with the gear change .. ..
Hope it Helps!
Worth trying simpler things first like the MAP - any of those items could be your culprit - but my money is on the throttle position sensor . Silly question probably, but is the throttle housing clean inside?
