fixing cracks in the indicator lens?
My vibrating engine has claimed a major casualty! My lovely indicators have developed some serious fractures, can these be fixed, plastic welding or low viscosity glue injections? Any ideas?![Image](https://imgur.com/a/Pc1XUtF)
Re: fixing cracks in the indicator lens?
could try captain tolleys creep and cure.
A little bit might seal it up.
I <3 that stuff! If I was going with my garrage staples I was thinking perhaps some epoxy casting resin? I managed to bridge a gap of several centimeters on my rear lights with that stuff...?
Do you think something like a windscreen repair kit will work? The plastic epoxy is probably nearer to plastic than glass in any case? Most of them work by creating a vacuum of some kind.
EG- https://www.amazon.co.uk/Windshield-Rep ... n+chip+fix
Drill a tiny hole at the end of the crack. This will stop it running further.
