breaking LHD 2.0
arthuy
breaking LHD 2.0
Post by arthuy » Thu May 10, 2018 8:50 pm
I wont be in a position to break this car immediately but happy to pass on parts to fellow owners.
The interior and front and rear side lights are gone.
Car is still running, I definitely wont need the wheels. The LHD specific parts wont be much use to me for example.
If you need anything let me know and I will check if it is still there and if it is something I will use.
89of480
Re: breaking LHD 2.0
Post by 89of480 » Thu May 10, 2018 11:22 pm
Are all the front lights gone? Do you have the fogs and the driving lights left?
Is the mirror/window switch still available?
Some plastic clips for the load cover would be really useful too
Thanks! :D
Post by jamescarruthers » Fri May 11, 2018 5:52 am
I could do with the centre air vent if it is unbroken, the driver's footwell vent (not just the trim but the bit behind that the trim clips to) and the tweeters.
I might need an undertray. There is chance one will turn up at tomorrow's meeting.
Post by Alan 480 » Fri May 11, 2018 12:26 pm
rear hatch struts (if they keep the hatch UP)
I'll swap you for a pair LHD headlights that i have :-)
arthuy
Post by arthuy » Fri May 11, 2018 5:19 pm
I will have a look, the car is at a friends so will need to check next time I am down.
Post by jifflemon » Fri May 11, 2018 8:55 pm
Thanks! :D
Have probably got a pair of driving lamps if these have gone
And a mirror/window switch too!
Will pack for the event tomorrow, just in case your joining us.
Are you keeping the A/C? If not is it R12 or R134? (interested either way!)
arthuy
Post by arthuy » Fri May 11, 2018 9:56 pm
Will need to check the a/c, it is the same as my own car so tempted to keep for spares. I will check to see if it is working and has gas.
89of480
Post by 89of480 » Sat May 12, 2018 12:06 am
Thanks! :D
I’ve just seen your message! I don’t think I’ll quite make tomorrow unfortunately, I’ll be getting MOT ready so I’ll be there in spirit though! I’m looking very forward to seeing what you’ve got though, I appreciate it! :D
arthuy
Post by arthuy » Thu Jun 14, 2018 10:18 pm
My friend is now back from holiday and I have been able to get a few parts off.
Please drop my a PM to remind me what parts you need if I havent got back to you, been a hectic few months.
arthuy
Post by arthuy » Sat Jun 23, 2018 5:04 pm
Got a few more parts off the car today.
Managed to get the screenwasher jets off and they look like they have been replaced.
Post by Alan 480 » Tue Jul 03, 2018 5:09 pm
do you have power steering hoses (well especially the one that is at pressure)
I know it's LHD, but I'll manage to 'lose' the extra length, but mine is NOT A/C so your power steering pump will have a banjo fitting on the top vs a section of 'bent pipe' but I'm sure I can over come that wee wrinkle . . . . .
triumphtoledo
Post by triumphtoledo » Wed Jul 04, 2018 7:59 am
How much for the exhaust manifold, please?
arthuy
Post by arthuy » Thu Jul 05, 2018 9:01 pm
Manifold has already been sold.
arthuy
Post by arthuy » Thu Jul 05, 2018 9:06 pm
PAS and parts are still on the car, the PAS is working fine. Will need to look and try get a photo for you to look at. You are welcome to come and have a look over the car Aberdeen isnt too far, but a fair old trek.
Post by Alan 480 » Sat Jul 07, 2018 9:03 pm
Ok let me know how you get on, but I reckon I might have found a solution
one of the guys I meet up with (Tuesday drinking) says that he can probably make up a replacement. the return line is easy and only needs aright angle connector and then re-route the return line close up bulkhead next to servo. . saves going around the houses (I assume this route was due to early cars having a 'cooling' pipe?)
noeljary
Post by noeljary » Wed Jul 18, 2018 9:47 pm
Hi,
Do you have a petrol pump for a 2 litre?
arthuy
Post by arthuy » Sat Jul 21, 2018 8:20 pm
I have a working fuel pump but will need to keep a hold of it until I have got the car broken a bit more. need to keep the car mobile.
arthuy
Post by arthuy » Mon Jul 23, 2018 2:19 pm
Got the headlamps off today if anyone is needing them, motors work well.
arthuy
Post by arthuy » Mon Jul 23, 2018 3:11 pm
Speedo gauges are in good orders and working ok. From an LHD car so dominant reading is KM.
Post by brinkie » Mon Jul 23, 2018 6:53 pm
I know I have repaired the VEM unit in Joris' car (and got some very tasty beers as reward :cheers: :cheers: :cheers: ), chances are I also did the speedometer but I cannot remember for sure.
