Front seats
Front seats
Hi all
The rear leather seats and door cards (front and rear) are now in place. What a difference.
1) I tried to remove the dashboard cards but they seem very very hard to remove and judging by the replacement ones they are held in place by several severe looking (nails?). Should I persevere or happily leave them there?
2) I don't have the proper tools to remove the railings for the front seats. Is it possible to leave them s as they are and slide the seats out?
Thanks in advance
Moi
Thanks in advance
Moi
Re: Front seats
The dashboard cards are difficult to remove. Al did ours with a large screwdriver with a cloth wrapped around it, then a bit of brute force to lever them out.
The seat rails are tricky, there is a bolt on each that goes right through the floor so the nut is under the car, covered in rust and gunk plus locktite. It's easier to remove the seat from the rails but you need 10 hands to get the replacements back on. Expect some blue air.
Re: Front seats
You need a torx 50 for the front seat; can post you mine if you need? I’ve one for a 3/8 ratchet and a normal screwdriver type one.
It’ll give you a few days to start soaking them in WD40 and building up your muscles, because boy oh boy are they tight!
Access is bloody awful too!
Re: Front seats
Thank you for the offer, I think I know where I can borrow a torx but WD-40 sure is a good idea. Not looking forward to doing that 8 times, joined the gym this morning just in casejifflemon wrote:You need a torx 50 for the front seat; can post you mine if you need? I’ve one for a 3/8 ratchet and a normal screwdriver type one.
Re: Front seats
if you have the seat belt 'pre-tensioners' of the mechanical variety, you MUST disable them before you start!!
there is a wee red button that you need to turn (across the way?) to disable them
Re: Front seats
Yep, there is a fair amount of explosives(?) under my seat and was going to wonder about that. I will look for the red button. Not as exciting as "cut the red wire" but saferAlan 480 wrote:if you have the seat belt 'pre-tensioners' of the mechanical variety, you MUST disable them before you start!!
Re: Front seats
god this is one hell of a job. it took forever to get mine out and you've gotta be so careful not to destroy the torx bolts.
it's an idea beforehand to clean up the bolts from underneath with a soft wire brush and plenty of whichever spray lubricant you're using (i think i had some silicone stuff) and to do so intermittently as you go. I had to go back and forth with my bolts, soaking, loosening and tightening and cleaning over several days to get em out.
but i reckon mine were particularly bad
good luck - it's worth it in the end tho!
1992 Paris Blue 480 ES
Re: Front seats
um, just wondering if you know that the leather interiors had a different carpet ? As I found, the carpet on the back of the rear seats doesn't match the standard boot carpet. While you've got the front seats out
it's not too difficult to change the carpet if you can get hold of it - there is a 'how to' thread on getting the central consol etc out. While you have the carpet out is a good time to deal with any rust on the floor as well. The job just keeps getting bigger.....
Re: Front seats
It is ever so slightly reddish on the back of the rear seats but I seldom drive from the boot. The leather is 2 tone leather so the grey bit does indeed match the carpet and I did give the underneath a good clean. No rust to be found heredragonflyjewels wrote:um, just wondering if you know that the leather interiors had a different carpet ? As I found, the carpet on the back of the rear seats doesn't match the standard boot carpet. While you've got the front seats out
Re: Front seats
no explosives ? ? ? ?frenchfries wrote:Yep, there is a fair amount of explosives(?) under my seat and was going to wonder about that. I will look for the red button. Not as exciting as "cut the red wire" but saferAlan 480 wrote:if you have the seat belt 'pre-tensioners' of the mechanical variety, you MUST disable them before you start!!
on mine it is stonking big spring (tucked in along side the seat rail), trust me they are re-settable, but only just and your bottom will be twitching as you get it near the reset point!!!
Re: Front seats
Found the red buttons, press down then indeed turn across. Why did I need to do that again?Alan 480 wrote:no explosives ? ? ? ?frenchfries wrote:Yep, there is a fair amount of explosives(?) under my seat and was going to wonder about that. I will look for the red button. Not as exciting as "cut the red wire" but saferAlan 480 wrote:if you have the seat belt 'pre-tensioners' of the mechanical variety, you MUST disable them before you start!!
Re: Front seats
Excuse me for butting in here Frenchfries, but @ Alan are the pretensioners resettable?? My 480 has always had a fired passenger side pretensioner and I'd like to reset it if possible.Alan 480 wrote:no explosives ? ? ? ?frenchfries wrote:Yep, there is a fair amount of explosives(?) under my seat and was going to wonder about that. I will look for the red button. Not as exciting as "cut the red wire" but saferAlan 480 wrote:if you have the seat belt 'pre-tensioners' of the mechanical variety, you MUST disable them before you start!!
Re: Front seats
@French Fries
the red button when turned ACROSS the car locks the trigger mechanism , kind of like a 'safety-catch' on a rifle
Rachel
if they are mechanical then you can pull the springs back to the correct location, but ruddy big spring and you need to get teh wee trigger re-set into correct orientation whilst you keep the tension in place.
this is from memory and done about 15 years ago
IT IS A NOT FOR THE FAINT HEARTED AND CAN BE DANGEROUS
so you are on your own here
remove the whole seat belt buckle assembly from the car (unplug the 'seat belt on' switch wire)
securely fix teh seat buckle assembly in a LARGE vice
I used a piece of 8mm (or 10mm?) threaded rod and a section of 4mm high tension fencing wire made into a 'loop affair'
then slowly pull the tensioner back
keep fingers well out of way and put the wee trapezoidal wedges in place
reset the red trigger back to across the way
re-install
I don't have any photos, all from hazy minding on . . . .
Rachel
re-install
Re: Front seats
Many thanks Alan, I think I'll give that one a miss
Re: Front seats
I think I will switch the Pre-tension belt system with my old one OR keep the little red button firmly "OFF".Alan 480 wrote:@French Fries
Rachel
I used a piece of 8mm threaded rod and a section of 4mm high tension fencing wire made into a 'loop affair'
re-install
Re: Front seats
Passenger seat in. In a week or so I will have retrieved enough energy to attack the other 4 torxs
Will also give me time to rejuvenate the leather
Re: Front seats
Hi all
I welcome any suggestions on rejuvenating the seat
I have looked a bit everywhere at cleaners and colours but not sure where to start. Professionally done I have been quoted between £160-£185 but since I am not gonna use Skip all the time I am looking at cheaper alternatives.
Thanks in advance
Moi
Thanks in advance
Moi
Re: Front seats
I use shoe polish on ours, I find it better than something like Gliptones conditioner for covering the scuffs where the surface has gone. Not to be done within a week of using the car unless you remember to sit everyone on an old towel or similar to keep the polish off their clothes.
Gliptones is great for softening the leather and keeping it in good condition, but it doesn't restore the colour.
Re: Front seats
ditto,dragonflyjewels wrote:I use shoe polish on ours, I find it better than something like Gliptones conditioner for covering the scuffs where the surface has gone. Not to be done within a week of using the car unless you remember to sit everyone on an old towel or similar to keep the polish off their clothes.
use 'neutral' first to get a decent seal on the leather, then try grey and some black to build colour to correct shade of grey/black, I just rub the polish in with tip of finger on a cloth.
Re: Front seats
when you move the seats or the pre-tensioner I'd switch off BUT
I'd always make sure the pre-tensioner is 'armed' when the seats are in the car. they are a safety feature
