Fuel tank
frenchfries
Fuel tank
Post by frenchfries » Mon Sep 25, 2017 8:57 pm
Hi all
I refuelled Skip at the week end. It was down to the last 2 green bars and the red range alert had just come on but I only managed to put 50 and a bit litres.
Knowing Volvo, are they a bit cautious when it comes to the capacity once on Reserve?
Moi
Re: Fuel tank
Post by jifflemon » Mon Sep 25, 2017 9:12 pm
60 litre tank isn't it?
Edit: and from the handbook......
frenchfries
Re: Fuel tank
Post by frenchfries » Mon Sep 25, 2017 10:14 pm
Aha
Makes sense. Definitely the 60litres tank.
Oh God, I guess I should not mention the fact that I have a users manual upstairs. How embarrassing :eek:
Re: Fuel tank
Post by jamescarruthers » Mon Sep 25, 2017 10:17 pm
You can check the calibration of the tank. Next time you fill up to the maximum, put the ignition on whilst holding the grey button without the hole down. Move the dial to vertical (fuel level) you'll see a report of how many litres the car thinks you have in.
frenchfries
Re: Fuel tank
Post by frenchfries » Mon Sep 25, 2017 10:44 pm
jamescarruthers wrote:You can check the calibration of the tank. Next time you fill up to the maximum, put the ignition on whilst holding the grey button without the hole down. Move the dial to vertical (fuel level) you'll see a report of how many litres the car thinks you have in.
Will do next week. Thanks for that :)
Re: Fuel tank
Post by jamescarruthers » Mon Sep 25, 2017 10:53 pm
And adjustment can be done by prising the little round plug out between the grey buttons. Insert a very thin Philips screwdriver to adjust the little potentiometer in there.
Theoretically a pin should get the little plug bit out but I've had some that I couldn't get out without slightly disassembling the switch assy!
Re: Fuel tank
Post by jifflemon » Tue Sep 26, 2017 7:26 am
It’s little gems of information like that, that make this place an absolute gold mine.
I know what i’m Doing when I fill the tank up for the October meet! :hopping:
Re: Fuel tank
Post by jamescarruthers » Tue Sep 26, 2017 9:22 am
I think the official line isn't to set the tank to the actual size or else there'd be no reserve.
Haynes has the figure in from what I remember, it's something like 3 or 5 litres less that the 47L or 60L tank
Re: Fuel tank
Post by Alan 480 » Tue Sep 26, 2017 11:58 am
for info I check it when tank is empty (nearly) and then confirm that it agrees when i add 40litres, TBH fairly accurate most of the time.
PS when the range gets to 11 iles the next step is ' - - - ' , which I took as being 'you're own your own from here pal' :-)
eye of ra
Re: Fuel tank
Post by eye of ra » Tue Sep 26, 2017 5:33 pm
jifflemon wrote:It’s little gems of information like that, that make this place an absolute gold mine.
Totally agree, to be bookmarked for when I have the dash back in.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Re: Fuel tank
Post by jamescarruthers » Tue Sep 26, 2017 5:59 pm
You'd better believe it!
