Stuttering under boost
ok so finally got car sorted and on the road but doesn't seem to want to boost and and can feel it holding back and jerking car (has Richmond) ' any ideas ? Thanks
- AleksanderHugo
Re: Stuttering under boost
I had similar symptoms and it turned out to be a broken wire to one of the injectors. At least I hope so, because I have just finished fixing the wire and I will make a test drive tomorrow
Thanks for reply ' yes I'll have a check at weekend along with everything else ' and thanks
Ok so checked various things to no avail so what i have noticed is in 3rd gear when i reach 3k revs it stutters for a few moments and then accelerates normal and does the same in 4th and 5th ?? Any help would be great
Check your ht lead connections! Could be those, I had a similar issue where mine died at 3k!
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
cranna21 wrote:Check your ht lead connections! Could be those, I had a similar issue where mine died at 3k!
what is ht less connections?
someone have fix the issue? i ve the same problem between 4200 and 4800 rpm, before and after this range is all perfect
The High Tension Leads; From the distributor to the spark plugs, and from coil to distributor.
They suffer a lot on the turbo due to under bonnet temperatures, so should be swapped out for new ones every couple of years.
Found the problem was head gasket and compression blowing into the coolant ' ie stuttering' no water in oil and only realised when checked coolant reservoir and bubbles galore
eeek! Hope you get it fixed soon.
Thanks fella , all stripped ready to get skimmed but quite busy at the mo so hopefully back together this year
