Wanted: Genuine mats. Faded okay just not worn through
I am thinking of shampooing my original mats and dying them back to the correct colour. Does anyone have a drivers one that isn't work through?
I'd also take a passenger one as I've gotten mine oil stained. This is less important as the carpet shampooed might deal with this.
This is for a RHD British car.
Last edited by jamescarruthers on Mon Jul 31, 2017 4:39 pm, edited 2 times in total.
Re: Wanted: Genuine mats. Faded okay just not work through
James
Not sure if it helps at all, but I have a front passenger and rear genuine carpet mats in excellent condition. I don't use them because I do not have the driver's mat (in any condition) and I use the hard mats anyway, so I took them out of the GT when I got it and they have been carefully stored in the loft ever since.
Be happy to part with them in your direction if you wanted - let me know.
Re: Wanted: Genuine mats. Faded okay just not worn through
David that is very kind. However, on my set it is just the driver's one that is worn through. In this instance I will give it a miss. Thank you though!
Skip came with 3 but I have replaced them with black ones. Could this be of any use to you? They are far from pristine as they are probably from 1992.........
They look better than mine from 1987!
No problem James!jamescarruthers wrote:David that is very kind. However, on my set it is just the driver's one that is worn through. In this instance I will give it a miss. Thank you though!
So, do you want them? I am off on holiday for a week this Saturday, I would only charge postagejamescarruthers wrote:They look better than mine from 1987!
Yes, I would love them for my dying experiment!
Send me a PM with how you'd like paid and the amount once you've worked it out. No rush.
Thanks.
Thanks.
Will check today.
Ironically, they were stored in the bag the new ones came in and when I took them out I then realised that the new ones came with fixing clips.
Thanks to you, all I had to do was to replace the original clips with those new nifty ones. The matt on the driver's side is now firmly in place
