LED day running lights
dxi310
Post by dxi310 » Wed Jun 29, 2016 12:37 pm
Can anyone recomend suitable tried and tested LED replacement BAZ15d bulbs for my 1995 480 Celebration
The lenses were looking dull and the bulb holders effected by heat ( i have all ready replaced 1 bulb holder) so i purchased bulbs from Ebay but they seemed to stop the pop ups working.
At present driving without DRL so any advise appreciated - dont mind paying top price for bulbs that work properly
Dennis
Re: LED day running lights
Post by brinkie » Wed Jun 29, 2016 9:14 pm
Avoid the cheap Chinese stuff like the plague. I mean these:
They overheat and the LEDs are of poor quality, so the result is...
https://www.youtube.com/watch?v=WzX3Ir45lRY
https://www.youtube.com/watch?v=M05b47UtM1k
I have now replaced them with a pair of these, but they started to flicker as well :(
http://www.ebay.nl/itm/262043129135
The best stuff are the ones with a built-in LED driver, most just have a resistor that limits current. I have noticed that the choice of warm-white LEDs (the yellowish-white that resembles regular light bulbs, not the blueish-white that attracts police and will cause MOT failure) is extremely limited and expensive in BAZ15d socket. You could try and replace the DRL socket (3 pins) by "normal" 2 pin sockets and put a bright LED bulb in which are very cheap in BA15s (single filament) socket. So you only have to turn on the parking lights and the lamp will be brightly lit.
