Central door locking
pangapz
Post by pangapz » Fri Dec 13, 2013 3:45 pm
hi, i found in the garage something like that http://www.ebay.com/itm/Universal-Car-R ... 83&vxp=mtr and i want to install it in my 480 but i cant find any central door locking module... where i have to connect that remote controller ?
glasgowjim
Re: Central door locking
Post by glasgowjim » Fri Dec 13, 2013 5:00 pm
Seriuosly dont its so much trouble that it is not worth it. Had 2 480s with remotes 1 professionaly installed along with thacham alarm (toad ??) + certificate and had to remove both due to random malfunctions.
glasgowjim
Post by glasgowjim » Fri Dec 13, 2013 5:03 pm
oh and a system like that shown in the picture would require a remotely controlled motor unit to be fitted in the drivers door.
do yourself a big favour and forget it . :bla:
pangapz
Post by pangapz » Fri Dec 13, 2013 5:12 pm
so, its impossible ?;]
glasgowjim
Post by glasgowjim » Fri Dec 13, 2013 6:49 pm
NO but not worth the effort IMHO
I still have the door with the extra motor remote unit in it and it did work for a while then it stopped and then started then failed at all the wrong times and places so I killed the system.
svenska axel
Post by svenska axel » Fri Feb 21, 2014 4:17 pm
surely, you only need to contact the microswith on the back of the drivers door lock barrel to activate the original locking. leave everything in place. just relay that microswitch from the remote control box, momentarily making contact as if the drivers door key is turned.
glasgowjim
Post by glasgowjim » Fri Feb 21, 2014 11:39 pm
Regardless of how easy /straightforward it sounds in real life the system is prone to random malfunction and is not worth the effort.
svenska axel
Post by svenska axel » Sat Feb 22, 2014 9:31 pm
it sent my pacemaker haywire. not wort the trouble. someone joined a couple of relays to my car under the dash and put two buttons on the dash to lock/unlock the car quickly inside.never caused any trouble. activated alarm and everything as normal when key was out of ignition.
svenska axel
Post by svenska axel » Tue Feb 25, 2014 3:02 pm
can post pictures and wiring all done in driver footwell if necessary. think it was done by the original lady owner at volvo for safety at night.
the rest is all down to how reliable your radio reciever is, you want a keeloq hopping transmission protocol if you want it secure. If someone 'grabs' your signal with a scanner, it wont work beacuse the code changes every time you open/close the doors with millions of combinations. A very common standard in car security but check if the unit has it otherwise its likely cheap junk.
Post by jamescarruthers » Tue Feb 25, 2014 3:09 pm
Svenska axel, your system will be working because the modifier (Volvo) will have added an extra motor to the driver's door lock.
It can definitely be copied but as standard the car is only capable of automatically locking the passenger's door on its own.
Volvo had this as standard on the USA-spec 480 prototype and the lock button, to lock all doors like yours, was activated by the switch we have as a blank next to the longrange headlights switch in the centre console, next to the heated seat switches.
svenska axel
Post by svenska axel » Tue Feb 25, 2014 3:24 pm
that surprised me. i thought my two tone es did it too. so yours really doesnt lock the drivers door from the passenger side.
Post by jamescarruthers » Tue Feb 25, 2014 3:29 pm
Nope, no 480 I've ever had does. It's a bloody good mod though that I've got the bits to do but never the time!
svenska axel
Post by svenska axel » Wed Feb 26, 2014 4:07 pm
if anyone wants the parts i can supply everything. was totally reliable.
