480 pictures of parts you tend not to see.
glasgowjim
Post by glasgowjim » Sun Dec 27, 2009 10:21 pm
Quite often the discouraging part of starting a job on a 480 for the first time is not being able to see what it looks like clearly. So when I have been stripping a car down I have taken a few photographs of different parts on the car. It is not a how to but hopefully make things easier when you come to do any maintenance for the first time.
glasgowjim
Post by glasgowjim » Sun Dec 27, 2009 10:40 pm
Various views of the moonroof assembly with the headlining stripped away.
motor
front drainpipe
rear drainpipe
motor from different angle.
bbf
Post by bbf » Mon Dec 28, 2009 9:16 am
Wow! Good idea! I know from my experiences, that it's much easier to get yourself to work when you know what to expect there. gives you more courage!
I have some pics. Could have more but lack of time/will to take photo during process.. Will document more in the future.
here are from my doors renewal:
this is how it looks under right mudguard (the car is without aircon. 480s with pushbutton aircon controls have white 4ballsmergedtogether outher space alien larva lookalike canister for vacuum near door hinges.)
This is right door latch mechanism. About the sticks:
Left: to outer door handle
Right: to locking mech - note the central lock motor at bottom
behind right - not installed - in pic you can see it's plastic eye: to inner handle
the blue part is open/closed switch
Door stopper - this one gives noise if not greased. and will produce play if worn out. but if the door craks when opening/closing, than the nailed pin on the other side of stopper is worn out.
The oval hole under it si for cabling.
Keylock at it's full renewed glitter! Two switces are seen - lock and unlock. There's the eye at the right side of white plastic - goes to latch mechanism.
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
glasgowjim
Post by glasgowjim » Wed Dec 30, 2009 12:40 am
the rear engine mount.
glasgowjim
Re: 480 pictures of parts you tend not to see.
Post by glasgowjim » Mon Jan 11, 2010 10:04 pm
timing belt
glasgowjim
Post by glasgowjim » Mon Apr 05, 2010 8:05 pm
Removing your dashboard/fascia the complete thing !!!!
the fascia is held on by two bolts at either end of the dash under the plastic plate at the door PLUS there are ALSO 4 small bolts here
you can see the far left one still has a piece of plastic in it :wink:
the black plastic heater casing you see is held on by the 2 bolts PLUS 2 more nuts accessed from the engine compartment.
from the engine compartment one NUT is located on the bulkhead heat shield the other NUT above the twin heater pipes.
glasgowjim
Post by glasgowjim » Wed Aug 25, 2010 10:48 pm
aerial and red lampcontroller unit.
glasgowjim
speedo sensor
Post by glasgowjim » Fri Aug 05, 2011 2:59 pm
speed sensor.
remove clip with a 6mm allen key
pgmm
Post by pgmm » Fri Jan 27, 2012 11:00 pm
The keyhole light - found it behind the door panel...
and put it back where it belongs, on top of the lock:
and it works as it was intended to!
To be continued...
Peter
1986 Volvo 480es red 217
1987 Volvo 480es blue 219 (sold)
1993 Volvo 480 turbo automatic red 235 (project)
glasgowjim
Post by glasgowjim » Sun Sep 16, 2012 6:05 pm
Side trim...
wkd rwd
Post by wkd rwd » Sat Dec 01, 2012 9:56 pm
great thread idea, certainly makes life easier when taking bits off, Thanks!
Got all my dash bulbs working/changed today, have to go at the door locks tomorrow
Willw480
Post by Willw480 » Thu Nov 27, 2014 5:35 pm
See for the speed sensor, is it located on the same place for a 2.0ltr auto?
I want to put mines back in after getting it fixed ( I hope) as it's had exposed wiring and has been patched up with some insulating tape -fingers crossed it sorts it.
Post by dragonflyjewels » Wed Apr 12, 2017 7:55 pm
o no, Glasgow Jim's photos have disappeared ! Can anyone help with a pic of the location of the speedo sensor on the gearbox ? cheers
Ade
Post by Ade » Wed Apr 12, 2017 8:30 pm
The sensor goes in the hole above the output shaft and is secured by a little bracket that is held in by an M8 cap screw into a hole directly above it (6mm A/F). If you can zoom in you might just see part of the tapped hole peeking out above the turbo oil return pipe in the first picture. A pig of a thing to try and do without at least removing the driveshaft.
O.C. 480 D.
Post by jifflemon » Thu Apr 13, 2017 12:26 pm
dragonflyjewels wrote:o no, Glasgow Jim's photos have disappeared ! Can anyone help with a pic of the location of the speedo sensor on the gearbox ? cheers
Am I the only one praying that its a temporary glitch? :help:
Post by dragonflyjewels » Thu Apr 13, 2017 6:19 pm
I think we are all praying............. so much information.............
Thanks to Ade for the pictures and info, hopefully our Brinkie refurbed speedo will be working soon !
glasgowjim
Post by glasgowjim » Mon Apr 24, 2017 10:24 pm
if you go to google images and type in glasgowjim photobucket you will get all my photos + a few from other people as well.
but still mno joy from photobucket support !
mathrock
Post by mathrock » Mon Mar 04, 2019 9:02 pm
Since these pictures are dead links, here's some pics of the door lock keyhole illumination / led / light:
