My windows mist up.
- volvofox
too high grade of humidity in the car !
remove the back seat lower parts and the truck mat. they must be verry wet. the "misting" point is earlier as your car is damp. I had this problem too, very quickly. since i sealed the rearlights and the roof (no sunroof!) Now this did not apear anymore! (no matter what we do in the car.... play cards, scrabble, drink, eat hamburgers.... (hehehehe)
"drying the floor with the tap open" is not a good option,(like special films to the windows) Best is to check for leaks in the car under the gardenhose, dry the foam parts like the rear seat bottoms and mats, and seal well. eventually check again.
donot use a humidity absorber, like them pots from rubson or bison: the directions for use say they turn iron quickly into rust (by experience!)
Luck
JPF
Luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- martinholmesuk
First time I did It thought that the car was on fire
it comes out just like fog but after a few mins it's OK but I still have mist.
I went out tonight and the window was misted up and i had to wipe it (very hard) yes it's like a film on the window.
Maybe it has flu?
Maybe it has flu?
Audi TT
Audi TT
- dragon
- Volvo 480 Club Europe CREW
Well, I don't think my car is wet in any way, but I will double check when I get back home this weekend....
Gaz Wilson
Gaz Wilson
Steamy windows
Hi Martin,
You have aircon although hardly used. I bet there is water gathered in the matrix because of a blocked engine bay drain pipe ( we have discussed this before ). See if it is blocked first by carefully putting a siutably sized stick up it, oo errr !
This happened to mine anyway, and when like now you start using the heater, it evaporates the water into the car.
I don't know if Dragon has aircon, and if not, you can take this theory and blow it away
Otherwise as everyone else says, check for water in the usual places, under floor mats etc.
Good luck
Gedda
Good luck
Gedda
2 Marina Coupe's, 2 Ford Capri's, 1 Austin Maestro, 1 Polo, 1 Volvo 440, 1 Volvo 850, and at last my '95 Celebration.
- martinholmesuk
- martinholmesuk
- martinholmesuk
Well sounds like your cars have contracted an STD(steamy turbo disease).
That fog thing definately isn't normal...!! You must have water collecting somewhere up the front, inside the dash / console / matrix???
Have you got a sunroof that whistles at high speeds?? This was the cause of my leaking when i first got mine. Check to see if your front seatbelts are wet at the bottom just out of interest...???
pol
pol
Are you loosing any water at all from your cooling system?. It could be that your heater matrix is leaking - even a very small leak will generate a lot of steam from your heater outlets as the water gets onto the matrix and is changed to steam. It can only go out one way - where your hot air is supposed to come from. Try some radweld or Bar-leak.
- martinholmesuk
- martinholmesuk
playing misty for me
Hi Martin,
I've just replied to you with the piccie. Hope you got it and good luck.
Gedda
Gedda
- martinholmesuk
Hi everyone. I stuck a stick up that hole and some light oil coloured stuff came out The mist is comming out of the vents and when i return the heat on loads and bloody loads of misty / fog crap comes out and floods the cabin and i can't see anything at all.
Audi TT
Audi TT
- martinholmesuk
- volvofox
Just be strict then, if there are no drains in the lowest points of the vents or in the "Heaterbox". just be brave and rip the thing in pieces, and look where the water comes from. For check on the heater radiator you have to run the car hot dough (!) This way, with the system pressurized you will be able to see a leak, else no.
One better test is to go to a garage and do the pressure test. They have special coolant caps with a manometer on it. If the system hasn't pressure, you know it leaks somewhere, seen your problem, the heater radiator.
but third wise, you could have maybe rainwater getting in the vent ducs, that doesn't get out , due to a clogged drain, you did not see yet.
So what did that oily stuff come from ? I think its coolant.( this is greasy too, and old one can also be rust coloured in stead of blue.) This means you must have a leaky heater radiator/or hose
Keep us informed, stay calm
Luck
JPF
Luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- dragon
Quick update on mine - can't find any dampness anywhere in the cabin, don't have A/C, cleaned the windows with a different wipe and the problem went away, but only until tonight, when it has returned (slightly) - haven't checked in the engine bay yet for any signs of leaks, but I don't think I am losing any water from the cooling system - Out of interest, when I turn my heat up, the "fog" that comes out only lasts for a few seconds, but it smells bad (like TCP, or like burnt electronics if anyone knows the kind of smell I mean - a bit like rootbeer smells, but without the sweetness) - the "fog" vanishes after a few seconds, but the smell remains, although not so strong - the "fog" can come out of the vents even if the windows aren't steamed up, so I think these are seperate issues. Also, if I stop the car and leave the engine running and turn the vent fan to 0, the fog slowly rises from the vents, but vanishes as soon as the car starts moving...
Oh yes, I have a whistling sunroof, but I always have done, and as we have had no rain in the UK lately, I don't believe it's letting in any water (the whistling hasn't got any worse in the 2 years I've had it, so if it was leaking, I think I'd have seen some evidence by now?)
Gaz Wilson
Gaz Wilson
- martinholmesuk
OK When I turn the heat on I get shed loads of fog and can't see ! I have now shut all of the vents and that's slowing it down.
Now when i leave the car and come back I can see mist in the car and coming out of the vents.
I went to tesco and got this anti mist stuff and that's keeping it at bay (tonight) first i wipe the windows with a wet clothe and then i wipe this anti msit stuff on.
seems to work ok but i still got this crap out of the vents. I'm so cold in the car because i have no heat so i need this sorted asap!
Audi TT
Audi TT
- volvofox
Tina turner's special
(not so serious, not intended offence mode)
DRAGON. stop singing as you enter your car. the flames out of your mouth heat up the car so fast, the windows mist up....
(serious mode)
holmes : do something. remove the duckts and plastic shields around the heater. the coolant evaporates as the watervapour enters your car, leaving the resins to stink. only some drops must be enough to make this amount of vapour.
dragon has no airco that speeds up the building of watervapour, but its very like wise, sinse the watervapour comes from the duckts too and the car smells, it is the same problem
but thinking of water only is now out a bit in doubt, isn't just something melting away there near the heater, dragon ? (since you describe the smell so well)
luck
JPF
(serious mode)
luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- martinholmesuk
