Cats in science
Posted: Wed Sep 24, 2003 9:03 am
A magazine held a competition, inviting its readers to submit
new scientific theories on ANY subject. Below is the winner:
Subject: Perpetual Motion
When a cat is dropped, it always lands on its feet, and when
toast is dropped, it always lands buttered side down. Therefore, if a
slice of toast is strapped to a cat's back, buttered side up, and the
animal is then dropped, the two opposing forces will cause it to hover,
spinning inches above the ground. If enough toast laden felines were used,
they could form the basis of a high-speed monorail system.
......... and then this mail got this reply from one of the readers
I've been thinking about this cat/toast business for a while. In
the buttered toast case, it's the butter that causes it to land
buttered side down it doesn't have to be toast, the theory works
equally well with Jacob's crackers. So to save money you just miss out
the toast and butter the cats. Also, should there be an imbalance between
the effects of cat and butter, there are other substances that have a stronger
affinity for carpet.
Probability of carpet impact is determined by the following simple
formula: p = s * t(t)/t(c)
where p is the probability of carpet impact
s is the "stain" value of the toast covering substance an
indicator of the effectiveness of the toast topping in permanently
staining the carpet. Chicken Tikka Masala, for example, has a very
high s value, while the s value of water is zero.
t(c) and t(t) indicate the tone of the carpet and topping the value
of p being strongly related to the relationship between the colour
of the carpet and topping, as even chicken tikka masala won't cause a
permanent and obvious stain if the carpet is the same colour.
So it is obvious that the probability of carpet impact is
maximized if you use chicken tikka masala and a white carpet in fact
this combination gives a p value of one, which is the same as the
probability of a cat landing on its feet.
Therefore a cat with chicken tikka masala on its back will be certain
to hover in mid air, while there could be problems with buttered
toast as the toast may fall off the cat, causing a terrible monorail
crash
resulting in nauseating images of members of the royal family visiting
accident victims in hospital, and politicians saying it wouldn't have
happened if their party was in power as there would have been more
investment in cattoast glue research. Therefore it is in the interests,
not only of public safety but also public sanity, if the
buttered-toaston-cats idea is scrapped, to be replaced by a monorail powered
by cats smeared with chicken tikka masala floating above a rail made from
white shag pile carpet.
crash
