Hi all I need the two pipes marked with white crosses if anyone can help?
2 pipes
Re: 2 pipes
Many thanks for reply and offer.I can get both from the Netherlands but am trying to source in the UK initially to avoid dreaded import duties. Cheers Norman.
Re: 2 pipes
Hey Norm, you may need to clarify which engine you have to get the right one. Early cars have an oval throttle body; later ones circular; and maybe other variations depending on pipes and sensor.
Can you put your VIN number up?
Re: 2 pipes
Thanks James. It’s for R3 which is a 1988 1.7 na the earliest engine I believe with the oval throttle body.jamescarruthers wrote: ↑Tue Jan 25, 2022 10:07 pmHey Norm, you may need to clarify which engine you have to get the right one. Early cars have an oval throttle body; later ones circular; and maybe other variations depending on pipes and sensor.
Re: 2 pipes
Ah, so a bit harder to find. I take it yours has a leak? I think you’ll have hands covered in RTV sealant soon!
Re: 2 pipes
IMHO self amalgamating tape might be neater and last a wee bitty longer?jamescarruthers wrote: ↑Wed Jan 26, 2022 9:24 amAh, so a bit harder to find. I take it yours has a leak? I think you’ll have hands covered in RTV sealant soon!
stretches much better than gaffer/ insulting / carpet tape and at least it has some integrity initially?
