480 cambelt cover
480 cambelt cover
Can anyone help I am after cambelt cover front and back there are three parts to cover front cover 3343732,cover upper 3344548, casing lower 3343735 casing lower is the main one I need but all would be helpful.Any info would be great.
cheers john.
cheers john.
Re: 480 cambelt cover
Hi
Lucky you , I have some covers . Must check .
regards
Marek
regards
Marek
In my treasures I found two covers , one plastic with Renault part number / 77....../ and second short / metal / without part number . Vadis says that You have B18E , ED , ES , EP , am I right ? You need inner and outer casings . Best for me , send VIN please . I`m charging my camera , so maybe today You will have pictures .
best
Marek
best
Marek
You could use 5mm bolts, drilled through a flat plate to draw the pulley off.
It works but only on a bigger cog , for smaller you need a puller .
Hi thanks very much for replying to my post I am pleased to say I now have the covers I need.
John.
John.
someone was before me , no gasket , a lot of silicon , not resistant of diesel fuel and oil !
Covers ! Unfortunately , small plastic cover is cracked , it`s a gift for you . Puller I ordered for a small cog is not suitable , but ... two bolts maybe works , Vadis says..... PULLER !They give only a part number , without a picture .
