480 cambelt cover
john denmead
480 cambelt cover
Post by john denmead » Tue Apr 14, 2020 6:27 pm
Can anyone help I am after cambelt cover front and back there are three parts to cover front cover 3343732,cover upper 3344548, casing lower 3343735 casing lower is the main one I need but all would be helpful.Any info would be great.
cheers john.
malkontent
Re: 480 cambelt cover
Post by malkontent » Thu Apr 16, 2020 6:01 pm
Hi
Lucky you , I have some covers . Must check .
regards
Marek
malkontent
Post by malkontent » Fri Apr 17, 2020 3:55 pm
In my treasures I found two covers , one plastic with Renault part number / 77....../ and second short / metal / without part number . Vadis says that You have B18E , ED , ES , EP , am I right ? You need inner and outer casings . Best for me , send VIN please . I`m charging my camera , so maybe today You will have pictures .
best
Marek
malkontent
Post by malkontent » Mon Apr 20, 2020 3:27 pm
covers : outer / plastic / 7700857429 , inner / plastic / 7700741120 , inner / metal / 7700598397 .Motor B18EP 115 , C030103 .
I need a cog wheel puller / small / , / ordered / must wait 2 or 3 days .
Post by jifflemon » Mon Apr 20, 2020 7:32 pm
You could use 5mm bolts, drilled through a flat plate to draw the pulley off.
malkontent
Post by malkontent » Mon Apr 20, 2020 8:48 pm
It works but only on a bigger cog , for smaller you need a puller .
john denmead
Post by john denmead » Tue Apr 21, 2020 1:57 pm
Hi thanks very much for replying to my post I am pleased to say I now have the covers I need.
John.
malkontent
Post by malkontent » Fri Apr 24, 2020 3:56 pm
someone was before me , no gasket , a lot of silicon , not resistant of diesel fuel and oil !
Covers ! Unfortunately , small plastic cover is cracked , it`s a gift for you . Puller I ordered for a small cog is not suitable , but ... two bolts maybe works , Vadis says..... PULLER !They give only a part number , without a picture .
malkontent
Post by malkontent » Wed May 20, 2020 12:59 pm
Still no gasket , and a butcher was there
Crankshaft seal 50 x 68 x 8
Gear seal 30 x 40 x 7
malkontent
Post by malkontent » Fri Jun 26, 2020 12:23 pm
simmering made some grooves
