Flaming urgent
Flaming urgent
Hi all ,my celebs cooling fan siezed during mot test and to cut a long story short went up in flames. Am looking for a cooling fan and motor with both connectors if poss. Am informed that a 440/460 will fit as well if anyone can help. Many thanks
Re: Flaming urgent
I was going to suggest this NOS one from eBay but it is for 1.7 N/A and Turbo only not 2.0.
https://rover.ebay.com/rover/0/0/0?mpre ... 4138540011
It does show that the Volvo original was Delco though so that may aid your search.
It looks like the B20 has different fans depending upon whether you have manual +/- air conditioning and automatic gearbox So it may be worth bearing that in mind if you are getting a second hand one.
I don’t have a 440/460 parts book to hand but I’d be pretty a confident that a 440/460 with the same gearbox and air conditioning status would suit your car.
Manual transmission: 3344879
Manual transmission plus AC -1993: 3344880
Manual transmission plus AC 1994-: 3345234
Automatic transmission: 3344880
Fan blade:
3342577 or 3345235
Washer:
3200922
Lock washer:
3342578
I presume being a British Celeb you have a manual, post-1994 car with air conditioning? Is that right?
Fan blade:
3342577 or 3345235
Washer:
3200922
Lock washer:
3342578
Re: Flaming urgent
Thanks James, 3345235 and 3344880 are the part numbers I have been given the originals were melted off. I have tried a few sources but no luck so far. Am hoping Fraser may be able to help otherwise I am thinking a trip to your neck of the woods (Lakes) is an option.
Re: Flaming urgent
Had a look at the 440/460 catalogue and 3344880 is used on 440/460 for motors:
B18 carb, B18U after 1992
B16F, B18EP, FP after 1992
B18 Turbo 1992-1993 with air conditioning
B20F manual transmission plus air conditioning
B20F automatic transmission without air conditioning
B20F automatic transmission with air conditioning -1993
The above seems like a minefield of confusion and I suspect that any 2.0 440/460 with air conditioning would be a good bet if you can't satisfy the above massive criteria!
- Murf
Re: Flaming urgent
For a short term fix you can get various sizes of universal electric radiator fans from Spal etc. One of them with the wiring adapted to fit the wiring plugs should work just fine
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
Re: Flaming urgent
Latest update, I have sourced a fan and motor(thanks Fraser). I still need the connector from the cem with as much wiring left on as possible. If anyone can help much appreciated.
Re: Flaming urgent
Glad you're getting somewhere with this Norm - I was a bit shocked when we were speaking yesterday! Thanks for your later message, btw...hence I didn't get back to you.
Good luck with the remaining parts!
Re: Flaming urgent
Thanks David, not as shocked as me. I am glad it happened in the garage during test and not while I was driving it!
Re: Flaming urgent
Hi all, still in need of a fan and motor if anyone can help
- WalkableBuffalo
Re: Flaming urgent
Is this your one by any chance Norm?
-Will
1991 480 ES, 1.7, Arctic Blue
Re: Flaming urgent
Yes mate, hopefully Mark will fettle it in time for mini meet. When I dropped it off two weeks ago for MOT I called in at yours after seeing your 480 on the drive. Did you get it thru the test?
- WalkableBuffalo
Re: Flaming urgent
Sadly wasn't there for the test. My Hermes driver told me there was a 480 there so went to check it out. Thought all the details lined up with your one. She looks in very good nick.
Should have told me you went by mine!
I've been too busy the past week to get it finished in so don't think I'll get through in time.
-Will
Re: Flaming urgent
Update! I am back on the road, many thanks to Ed for the parts DC Walker for the wiring and Fraser for doing his best.I would have struggled without the forum that's for sure. Also thru the M O T with no advisories, so alls well in the wedgie world again!
Re: Flaming urgent
Excellent news on all fronts, Norm - well done!
See you on Sunday then, when I shall be driving your car's twin sister...
