Windscreen nozzles
263761802630
Ebay spot
Ebay spot
Re: Ebay spot
£30!!
I'll stick to my brand new alternatives thank you very much
- WRDendy
Re: Ebay spot
Agreed. having two jets either side is quite a nice upgrade as well.
Semi related, I was driving behind a classic range rover the other day and thought the rear washer jet looked familiar:
https://www.ebay.co.uk/itm/Land-Rover-R ... Sw8gVX2sKk
Clearance over the wipers might be an issue but worth looking into if looking original is important.
Formerly known as 'Jaster'
Re: Ebay spot
I covered this on my thread a while back.
The landrover items look good but need modified due to the length of the threaded part.
arthuy wrote: ↑Tue Aug 01, 2017 8:01 pmdcwalker wrote:
Review of the short landrover screen washer jet. They seemed ok but are too low, when I tried to adjust the jets it either went over the roof or bottom of the screen, conclusion was that I needed a taller jet like the originals. I picked up a pair of the brass jets which are almost exactly the same size.
They were £5.99 the pair. http://www.ebay.co.uk/itm/PAIR-UNIVERSA ... 2749.l2649
The bottom clears the wipers although I had to removed the wiper linkage to get the drivers side fitted, which of course meant a sheared bolt. I managed to drill and thread it though.
They brass jets hit the middle of the screen without needing adjusted. I am glad I ordered them as the drivers side was on its last legs.
