Wanted: Undertray
Wanted: Undertray
Wanted: Undertray
Undertray wanted along with fasteners and blind nuts in the subframe
Ideally, could someone bring one to the May 12th?
Re: Wanted: Undertray
Good news bad news:
Bad news, they are very difficult to find.
Good news: when I "finally" found one I chenged the fasteners to those and they are working very well:
https://www.ebay.co.uk/itm/10x-Volvo-Pl ... 2749.l2649
I can bring you the 4 you need for when you will have your undertray
Very good of you! Thanks
And remind me cos I will forget
Bump!
I have the blind nuts for the subframe but still need an undertray and bolts. Does anyone have one?
add the phrase 'spare and in good nick '?jamescarruthers wrote: ↑Sat Oct 13, 2018 5:09 pmBump!
the bolts are actually ruddy coarse threaded 'self tappers' , try Screwfix ( https://www.screwfix.com/p/carbon-steel ... pack/40117 )
or I have some left over , liberated from the front wing of a Vectra if you only need the four for postage? you need another two for bottom rear edge of front wings (one each side) and the same around front wing top-edge . ..
probably 'trashed' if you do get one as well; mine is stiched in a few places with cable ties and the 'captive nuts' in the subframe were replaced with pieces of suitable 'tapped' SS plate, pop-rivted into place. I got a stack of ID plates , 5" x 3" approx 18SWG so very handy for these sort of operations
There are a load of 440's at Lake's so I'm sure one of them will have one in decent nick... I just need to get there and work out how to get underneath them (the decent looking ones all seem to be on long grass).
I've also approached W R Composites to copy one which might not be too expensive (he does snow caps and front spoilers at £50 each). I have one to copy but it's not mine to keep, it actually belongs to the car I recently sold and forgot to re-attach it!
Right now, I'd love the easy option of one just arriving in the post or me driving somewhere closeish to collect and fit next month.
I'll give you a shout if I need the bolts, but you are right, they're just generic things so I'll be able to get something locally.
Hi James
The ones I suggested are still available on Ebay.
Got 'em! thanks Davidfrenchfries wrote: ↑Sun Oct 14, 2018 9:57 amHi James
