Wanted: Headlight washer valve three way valve
Headlight washer valve three way valve required. Found cap missing from mine and the reason pipe was disconnected.
Anyone got one?
Anyone got one?
Re: Wanted: Headlight washer valve three way valve
Think I may have one of them - Will check spares in daylight
Thanks!
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Good idea! The original has the input at 90 degrees so have managed to go with this:
https://www.ebay.co.uk/itm/VOLVO-740-76 ... 3f96d8b238
if that one doesn't I've got one
Thanks. I am not 100% sure the sizes are correct so may well have to take you up on that offer
Aaaaaaargh! The one I posted (black one) is for Stuart Little's 480!
The joys of buying on the internet
Part no longer available from Volvo. P/N: 3402213
Two from Charlton Volvo on eBay. One that looked right was far to small. One could be right size but has lower pipe at wrong angle.
More research shows that Land Rover part number DCP6656 will do the job. Looking on Google images, it seems that back in the day it looked identical to ours. Now it looks slightly different but the pipe sizes and dimensions still match ours.
Now have working headlight washers again.
£12.95 from Land Rover dealer. Available much cheaper on the internet but I was short of time and they could get it next day
does your Mrs not check your Pay-Pal account?
I know when SWAMBO has been on a buying spree cos it says I've bought x, Y & Z ! She doesn't like to use her account!!
Is there a non return valve in there?
I would be tempted to get a cheap generic non return piece and a standard T-piece, should be able to get them alot cheaper.
You could also try a friendly pet shop, the type thing for fish tanks etc.
