Volvo 480 2.0l Celebration "Breaking" all parts available
Re: Volvo 480 2.0l Celebration "Breaking" all parts availabl
Post by dragonflyjewels » Sat Jun 17, 2017 8:27 pm
Please be patient with werrington1, his daughter has been ill. I'm sure he'll be back online soon.
timrosser
Post by timrosser » Mon Jun 26, 2017 7:52 pm
Hi Josh, I hope everything is settling down for you at your end, keep me posted if you are able to post out the parts still.
Very best
Tim
Werrington1
Post by Werrington1 » Wed Jul 12, 2017 11:00 am
Still quite a lot of bits left,
Engine 2l with 50k miles on - will break the engine if people want bits from it
Gear box with 50k miles on, really smooth gear change
Wing mirrors, both sides in green
Washer bottle
Passenger electric window mechanism
Fuse board and cover
Loads of trim bits
Door catches
Window looms
Nose cone
Window glass - all available
4 alloys with good tyres. 2 are nearly new tyres
Space saver wheel
Radiator fan plastic cover/cowling
ABS pump
Brake calipers, some are pretty new.
Seat belts
Plus loads more.
Will start getting pictures up at the weekend.
If there is anything you want pictures of before, send me your email address and I will send them over.
Josh
frenchfries
Post by frenchfries » Wed Jul 12, 2017 3:52 pm
Werrington1 wrote:Still quite a lot of bits left,
Washer bottle
Loads of trim bits
Door catches
Window looms
Nose cone
Space saver wheel
ABS pump
Seat belts
Plus loads more.
Josh
I am after the passenger rear side window rubber. Mine leaks I think.
Werrington1
Post by Werrington1 » Wed Jul 12, 2017 5:18 pm
Washer bottle
Loads of trim bits
Door catches
Window looms
Nose cone
Space saver wheel
ABS pump
Seat belts
Plus loads more.
Josh
Yes I have that. I will get it removed, and if in good condition, I will send you a picture of it. Will probably be at the weekend.
eye of ra
Post by eye of ra » Thu Jul 13, 2017 5:23 pm
Just a note of caution. Never tried it so could be wrong but the rubber was not a separate part so may not be reusable once removed.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
frenchfries
Post by frenchfries » Thu Jul 13, 2017 7:27 pm
eye of ra wrote:Just a note of caution. Never tried it so could be wrong but the rubber was not a separate part so may not be reusable once removed.
True. I checked the P/N and it seems to be 1 single piece. I don't mind though, my Volvo guy can install it for me if needed :)
Werrington1
Post by Werrington1 » Fri Jul 14, 2017 2:18 pm
Ok, I will check it tomorrow but pretty sure the glass etc is in good condition. Will get a picture sent over.
Post by brinkie » Fri Jul 14, 2017 7:16 pm
Hello Ger and Martin, and welcome!
Those in need of a speedometer sensor: these parts are unavailable new.
Be aware that in many cases the sensor is not at fault. Measure with an ohmmeter between pins 6 and 12 of the grey connector behind the instrument cluster. If you measure low ohms (say anything between 3 and 10 ohms), the sensor is OK. Usually the wiring to the sensor breaks when work has being done to the gearbox or the clutch.
If the sensor is OK, try to solder pins 6 and 12 of the grey connector on the main board of the instrument cluster.
This will solve a faulty speedometer in many cases.
Rear lights in good condition have unfortunately become "unobtainium".
Post by Alan 480 » Mon Jul 31, 2017 6:06 pm
Do you still have the front sub-frame.
no rush and it can wait (winter project) until all the other bits are gone, engine & front suspension are attached to it!!
or if any other folk have a subframe for a 2 litre post 93 version (car is Sept 93) nearer ABZ :-)
Werrington1
Post by Werrington1 » Mon Jul 31, 2017 7:21 pm
Alan 480 wrote:Do you still have the front sub-frame.
Hi
I have sent ycan u a message.
Josh
gentlegiant
Post by gentlegiant » Tue Aug 01, 2017 12:50 pm
Hi! Perfect timing. My celebration has just been pranged front left wheel arch panel. Have you got one still? Also could do with a boot release cable. Thanks - G PS What colour is yours..?
Werrington1
Post by Werrington1 » Tue Aug 01, 2017 5:54 pm
gentlegiant wrote:Hi! Perfect timing. My celebration has just been pranged front left wheel arch panel. Have you got one still? Also could do with a boot release cable. Thanks - G PS What colour is yours..?
Hi,
Unfortunately the wings have both sold! The car was dark green.
Josh
gentlegiant
Post by gentlegiant » Wed Aug 02, 2017 7:16 am
Ok - thanks anyway :)
Willw480
Post by Willw480 » Sat Aug 19, 2017 9:12 pm
Hi there! I have a 2.0ltr celebration and I'm looking for the auxiliary fan belt tensioner for the smaller, secondary belt that powers the alternator and a/c unit. Mines has broken off after a monumental fault... Can't seem to source one anymore online or from a dealership. Would you have this available?
Cheers,
annieosc
Re: Volvo 480 2.0l Celebration "Breaking" all parts available
Post by annieosc » Sat Nov 04, 2017 7:37 am
Hello there........I have a 2 ltr celebration 1995.I have problems with my instrument panel(the info centre is dead).I wondered if you stlll had one.
thanks................John
Post by dragonflyjewels » Sat Nov 04, 2017 9:35 am
If it's definitely the panel rather than a loose connection, it's better to send the whole cluster to brinkie in Holland for a refurb. than buy a secondhand one - last one we had done cost 70 euros. brinkie will also replace the poor quality cog in the speedo - these all fail eventually so well worth getting that sorted. You can pm him, user name is brinkie.
JimAitken
Post by JimAitken » Sat Nov 04, 2017 7:10 pm
Do you still have the front seat belts popup arms with rollers intact? And is the front windscreen intact? Also looking for front springs/suspension units.
I'm based in Cornwall as well. Is it possible to drop by with a shopping list?
cheers
Jim
current: 480GT, V70 D5
previous: 480Turbo, 440, 850, V70 Classic. Renaults 4/5/6/20, Mini Cooper S (1968), Alfasud ti
Werrington1
Post by Werrington1 » Sun Nov 26, 2017 2:50 pm
Hi Jim,
Sorry for the late reply, I have had a busy few months and my partner gave birth last week.
I will check the windscreen as i think it's good! Suspension is all there alone with engine, gear box, and quite a few other bits. Happy for you to give me a list and I will see what I have or you can come and have a look for yourself. If you send me an email or phone number I can send some pics aswell of what's left if you like.
Josh
timrosser
Post by timrosser » Mon Dec 18, 2017 5:35 pm
Hi Josh- congratulations on your new arrival!
Next year I would like a rear carpet for the boot. And the black dashboard surround (that houses the instruments and switches) Might have to be a post thing although I do get to Bristol & Southampton sometimes, both for some restoration I wont be doing for months so no pressure getting back to me.
All the best
Tim
