480 parts mini hoard sell off
Hi guys not been around for a long time since i sold my last 480 nearly 10 years ago and the time has finally come to sell off the remains of my 480 stockpile. The parts have been in dry store for years so i don't know the exact functional condition of everything, so i apologise in advance for any issues. Please PM me if you are interested in anything, i might be able to test certain items as I also have a non moted 480 turbo to sell off. I'm happy to post most stuff at buyers cost, but large heavy items will have to be picked up. Thought i'd give you guys first dibs before i put stuff on ebay, i haven't put prices on things yet but sensible offers considered.
Quantities available – Description - Visual condition/functional condition (notes relating)
GC : good condition, RC : reasonable condition, UNC : unknown condition, PC : poor condition
X1 pair – Door cards RC/GC (few storage marks, no speakers or door pockets)
X3 - Intercooler to throttle body rubber U shape hose GC/GC (Few of the usual rub marks)
X1 - Blue silicon water pipe from engine to heater matrix RC/RC (one end is a little chewed but still usable, part no. 451 858)
X1 - blue silicon turbo pressure outlet S shape hose GC/GC
X1 - Sump RC/GC (few rust scabs, needs a clean and paint)
X1 - Gearbox to engine lower brace GC/GC
X1 - N/S front brake caliper and bracket RC/UNC (old blue high temp painted, stored for quite a long time)
X2 - Aux water engine coolant pump GC/UNC (tested both and the motors run ok but whether they leak or not?)
*SOLD BOTH*
X1 - Timing belt idler pulley – static GC/GC (nice and smooth)
X1 - Timing belt idler pulley – tensioner GC/GC (nice and smooth)
X1 - ABS torque bar pivot bearing – bar runs across rear of bay GC/GC (kept spare as found they do wear badly)
X1 pair – rear light cluster bulb holders GC/GC (very little corrosion)
X2 - clutch cables x1 GC/GC x1 RC/RC (x1 has a few wear marks)
X1 – Handbrake cable RC/RC (Boots in good shape, little corrosion on cable stops, not sure which hand)
X1 – Power steering cooler line RC/RC (pretty rusty with some pitting but will clean up and paint ok)
X2 – Throttle cable GC/GC
X2 – Starter motor GC/GC (both tested, motors run and throw ok)
X1 – Two speed Rad fan GC/GC (tested and both speeds work)
X2 – G/box side driveshaft RC/RC (CV joints in good shape but boots are pretty perished)
X1 – Non G/box side driveshaft RC/RC (CV joints in good shape but boots are pretty perished)
X1 pair – Rear bumper upper metal screw spreader plate strips GC/GC (located where plastic bumper skin fits to metal beam)
X1 – Rear bumper beam PC/PC (pretty rusty along the bottom but I have salvaged one before by welded plates in, so don’t know if people are doing similar and want a donor??)
X2 – rear wiper arm GC/RC (little white corrosion, pivot tabs snapped on both nut covers)
X1 – steering column RC/GC (upper and lower shaft with UJs, all ok)
X2 – Rear engine mounts RC/RC (rubber horseshoe has some splits on both, pretty normal)
X2 – front engine mounts RC/RC (couple of small dings from storage but uable)
X1 – Panhard rod RC/RC (Bit rusty and bushes look ok)
X1 – Alloy top turbo inlet manifold in black GC/GC
X1 set – rear timing belt covers x1 metal x1 plastic GC/GC (both go behind pulleys)
X1 pair – Bonnet hinges in Red GC/GC (no slack on hinges)
X2 - g/box clutch lever boots GC/GC (no splits)
X1 - Engine damper and mounting bracket RC/RC (bit of slack on change of direction but most are like this)
X1 – Turbo oil feed line from engine GC/GC
X1 – Complete old type oil drain line and silicon rubber hose GC/GC (screw type to turbo, hose has no split)
X1 set – timing belt synchronous pulleys GC/GC
X1 – Rear middle centre consul RC/GC (No cracks in plastic body, no ash tray, x2 small splits in front of cushion section)
X1 – Complete turbo head with both inlet and exhaust manifolds RC/RC (needs a good clean, unknown mileage, would split up if required)
X1 – Old type turbo exhaust housing minus three bolt elbow GC/GC (x1 little crack on turbo centre cartridge mating face)
X1 – Old type turbo exhaust housing three bolt elbow and custom adaptor plate to fit saab 9000 T25 turbo GC/GC
X2 - ABS units GC/UNC (been stored for a long time, think they are ABS mk2’s)
X4 - M59 yellow label turbo g/box’s GC/RC (unknown mileage but all taken off runners so should be ok)
*on ebay*
X1 - Turbo engine RC/RC (usual block rust, unknown mileage, dry stored a long time, turns easily with spanner, bit grubby)
*on ebay*
X1 - pair doors with glass in Red GC/GC (both pretty rust free which is very rare now)
X1 - dash panel GC/GC (no cracks in body, x2 of the screw holes are broken which is normal and has an LED mount hole in lower face)
X1 - clocks RC/GC (face has some peel that’s been painted)
X1 - MAF GC/UNC (should work as I wouldn’t have kept it, 0280 212 021 bosch 3 547266
X1 - Turbo fuel pump and lock ring GC/UNC (motor runs but stored for a long time)
X3 - Indicator stalk GC/UNC (not tested)
X1 - Wiper stalk GC/UNC (not tested)
X1 - headlight switch GC/UNC (not tested)
X1 pair – rear fog lights GC/GC
X1 pair – front wing side repeaters GC/GC
X1 – info centre switch GC/UNC (not tested)
X1 – headlight beam unit GC/GC
X1 – O/S headlight plastic cowl GC/GC
X1 pair – front fog lights GC/GC
X1 – N/S headlight/motor ass complete GC/GC (motor runs, gold paint a bit scratched)
X1 – Crankcase breather valve and foam GC/GC (no cracks)
*SOLD*
X1 – Fuel roll over valve GC/GC
X1 – Engine oil pump GC/UNC
X2 – PAS pump GC/UNC (taken from runner but stored a long time)
X1 – Sunroof motor) GC/GC (motor runs)
X1 – Rear light cluster centre section GC/GC (No cracks, chips)
X1 – O/S Rear light cluster PC/RC (chipped badly in a few areas)
X1 – N/S Rear light cluster GC/GC (no chips, refurbed so looks like new)
X1 pair – window motors GC/GC (tested ok)
X1 – used upper to lower inlet manifold gasket GC/GC (no harm I reusing)
X1 – injector rail and injectors GC/UNC (injectors taped up but stored a long time, brown)
X1 – O/S long range light GC/GC
X1 - Rear view mirror GC/GC
X1 pair – rear wing side markers GC/GC & GC/RC(x1 perfect seal and x1 perished)
X1 – O/S seat belt support arm GC/GC
*sold*
X1 – Ignition barrel with key and new allen key bolts GC/UNC (pretty sure I stored it as a good spare)
X2 – washer pump GC/UNC (motors run)
X1 – headlight washer pump GC/UNC (motor runs)
X2 – Crankshaft position sensor GC/UNC (take off runners but stored a long time)
X1 – Boost solenoid GC/UNC (taken off runner but stored a long time)
X1 – Fuel cap GC/GC
X2 – heated seat switch panel GC/GC (x1 with long range switch x1 without, maybe 440 one)
X1 – ECU bosch green label GC/UNC (taken from a runner but stored a long time, 0280 000 959)
X1 - Small rectangular fill in trim I think goes under glove box GC/GC
X3 – Engine knock sensor GC/UNC (taken from runners but stored a long time)
X1 – Engine oil pressure sensor RC/UNC (taken from a runner but stored a long time)
X2 – Brake light switch GC/UNC
X1 – turbo idle valve GC/UNC (taken from a runner but stored a long time, these are notoriously hopeless so I’m nervous about even selling it)
*SOLD*
X1 – spare wheel bolt plastic spacer GC/GC
X2 – idle valve brackets – GC/GC & GC/RC (x1 is a little baggy but usable)
X1 pair – rear seat side pockets GC/GC (missing the screw panel trims inside)
X1 pair – A pillar trim GC/GC
X1 pair – Scuttle panels GC/GC & RC/RC (PS has a crack in it but still usable)
X1 pair - door step trim GC/GC
X1 pair - door pockets GC/GC
X1 pair - c pillar trim GC/GC
X1 – N/S rear cluster inner trim GC/GC
X1 – Ignition barrel lower cowl GC/GC
X1 – Greddy turbo timer mounted in front centre consul trim box – GC/GC (worked when removed)
X1 pair – laser cut VOLVO stainless steel panels to mount in door lower recess – new, never fitted
Volvo 480 turbo H reg in Paris blue, bad bits - very rusty arches, sills and door bottoms, rear lights broken, no mot, cloth interior bit manky, was running quite right when parked up - throttle hesitation probably usual 480 electrical gremlin good bits - mechanically pretty good, Richmod 2 ecu, larger injectors, 3 bar map sensor, custom stainless exhaust, lowered, 15" aftermarket alloys, turbo timer. More details and pics to follow
Think i have some more ecus and clocks kicking about somewhere......
thanks Edd
*SOLD BOTH*
*on ebay*
*on ebay*
*SOLD*
*sold*
X1 – Fuel cap GC/GC
*SOLD*
thanks Edd
www.teamvolvo.co.uk
www.teamvolvo.co.uk
Re: 480 parts mini hoard sell off
Hello again Ed. I'm interested in the crankcase breather, please.
Tell me more about the car....
Where you based?
Where you based?
Hi,
We'd be very interested in the nearside rear light cluster and n/s headlight with pop up motor. Hubby is looking through the list for anything else as we have 4 x 480's to keep on the road so the list will doubtless grow. Whereabouts are you if we need to collect ?
thanks
thanks
Hi guys sorry for the slow response, had some log in issues... I'll publish more info regarding the car as soon as I can. James I assume...the crankcase breather is off a turbo I notice the 480 on your message is a non turbo? The light cluster is nearly finished so I can show pics soon, has come out pretty nice. I am based in Somerset
www.teamvolvo.co.uk
www.teamvolvo.co.uk
Price on m59 gearboxes?
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
Ed
Intereste din:-
Timing belt pulley
Rear wiper
which dash panel? the big section surround or teh wee tiddly bit ? ? ? Mine is cracked top left
long range lights (i have need of ONE, but can't remember which . . . . )
Intereste din:-
Timing belt pulley
Rear wiper
m59 Gearbox's I'd be happy with £50 each, they'd have to be collected...
Alan - which pulley the static or pivoting? The dash panel is the main large black face piece the clocks and switches mount to.
Cheers edd
Cheers edd
www.teamvolvo.co.uk
www.teamvolvo.co.uk
Yes, mine is a N/A ES with B18E from 1987. Is the breather different on turbos? I'm after the little separator tube thingie that pushes into the engine.
James - yes the es and turbo breather outlet are very different. If I remember rightly the es ones are a plastic tee, turbo ones have a diaphragm non return valve to stop the sump being pressurised under boost.
www.teamvolvo.co.uk
www.teamvolvo.co.uk
I have someone else interested in the breather valve who has a turbo so if you don't mind James I'll sell the valve to them....
www.teamvolvo.co.uk
www.teamvolvo.co.uk
Yes, go ahead Ed. I forgot the differences-- haven't had a turbo for a few years now.
http://s297.photobucket.com/user/MrE-1/ ... sort=3&o=0
http://s297.photobucket.com/user/MrE-1/ ... sort=3&o=1
http://s297.photobucket.com/user/MrE-1/ ... sort=3&o=2
http://s297.photobucket.com/user/MrE-1/ ... sort=3&o=3
http://s297.photobucket.com/user/MrE-1/ ... sort=3&o=4
www.teamvolvo.co.uk
www.teamvolvo.co.uk
both pullies, I had one pulley squeal, so swapped both and forgot which was squealling assume the 2litre same as 1800 turbo?MrE wrote: Alan - which pulley the static or pivoting? The dash panel is the main large black face piece the clocks and switches mount to.
Cheers edd
main dash surround, sounds like the bit I'm after, smooth plastic, black, I'd post a photo but no idea how as I don't have any 'web based album'
I have to say I'm not 100% sure if the idlers are the same on the 2l, I haven't worked on one but I find it unlikely they'd be
Different
This is the dash panel on my old 480 Alan. £10 each for pulleys and what do you think is fair for the dash panel as good examples are pretty rare. Also would you want it posted? Cheers
Different
www.teamvolvo.co.uk
www.teamvolvo.co.uk
Yes it would need posted, no idea what the differences are if any on the idlers, I'll have a quick look and see if there are any markings onmine.
the dashboard is still in the car? !! I thought it was from a pile of bits, or is this the car that you are trying to sell, paris blue H plate? that dash looks good , but so does mine, top left corner is where mine is suffering the most . . . .
I'd hate to have a car 'broken' if it could be saved. . . .
but if it IS going to breakers then I'll make you an offer for whole lot once checked part numbers, can you put me down as first refusal if DEFO scrapping
Lol no this is an old photo of my sweet k plate Paris blue 480 turbo I sold 10 years ago! The car I have for sale is no where near as nice as my old one! It has plenty of useful bits. I'll do a proper post in cats for sale with all the specs when I can clean it and get some decent pics. It's definitely a scrapper really I have welded the sills several times.... the rest of the stuff is a pile of bits from loads of other cars....
www.teamvolvo.co.uk
www.teamvolvo.co.uk
www.teamvolvo.co.uk
www.teamvolvo.co.uk
www.teamvolvo.co.uk
www.teamvolvo.co.uk
www.teamvolvo.co.uk
www.teamvolvo.co.uk
