jamesy12345
Post
by jamesy12345 » Wed May 11, 2016 12:41 pm
Alan 480 wrote:on the dash surround, where is hair line crack starting (as If I need to ask?)
i'm in ABZ so can you maybe weigh it and I'll see what postage cost would be. . . . . it's not heavy just bulky for GPO
I was thinking of the sticky vinyl repair method, as it would save taking dash apart (again)
have you still got BOTH snow mats? NB I could use it to catch the leak from teh heater matrix (I assume it is not available) although I might try and repair our one as car is off the road for at least next three months
and there is a spare that has been 'repaired' with silicon sealant
Alan the cracking is in the usual place, top left - I tried taking a photo although my camera is crap...I'll post it up later on see what you make of it
Snow mats are a set of 4 fella. Should be no problem to post them to Aberdeen
//edit
found the (fuzzy) photos, as you can or rather can't see it's hard to see the crack although it is there
and limits for parcel sizes
http://www.postoffice.co.uk/mail/uk-standard
if I can make the snow mats into a parcel less than 61cm long x 46cm wide x 46cm thick & less than 2kg it's only a fiver a go for 2nd class...not sure on the length of the largest mats though. The dash surround should be either 2.85 or a fiver depending on length (parcel needs to be under 450 mm long for the lower price)
heater matrix has gone unfortunately
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Post
by Alan 480 » Thu May 12, 2016 11:56 am
Looks better than ours. !
have you scrapped the car?, if not do you still have the frame that the dash-surround fixes onto? most of the palstic fittings ./ screw holes are shot on ours so might worth doing the whole thing?
jamesy12345
Post
by jamesy12345 » Thu May 12, 2016 12:44 pm
--------double post in error-----------
jamesy12345 on Thu May 12, 2016 12:53 pm, edited 1 time in total.
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
jamesy12345
Post
by jamesy12345 » Thu May 12, 2016 12:46 pm
Alan 480 wrote:Looks better than ours. !
the car has gone now fella unfortunately, only these bits & bobs left
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
doingitsideways
Post
by doingitsideways » Fri May 13, 2016 7:11 pm
jamesy12345 wrote:
Stop masquerading as someone who knows what they're doing, with all the necessary toolage.
They're my ratchet spanners and Torx sockets!
Hammers can't fix a 480!!!
jamesy12345
Post
by jamesy12345 » Fri May 13, 2016 7:15 pm
doingitsideways wrote:Stop masquerading as someone who knows what they're doing, with all the necessary toolage.
I was looking at the photo thinking...I don't recognise them spanners....
my pound shop socket set must have been 'just out of shot'
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Post
by dcwalker » Mon May 16, 2016 1:33 pm
If it's any help I have the frame behind the dash surround on Nipper whom I am dismantling - not all screw holes are intact but most are; is it any good to you?
jamesy12345
Post
by jamesy12345 » Mon May 16, 2016 3:11 pm
update
Relay cover
interior light
boot/fuel flap release lever cover
Snow mats
Ignition coil
Radiator fan & surround
Wing mirror glass both sides - provisionally sold
Recirc valve - provisionally sold
Dash surround in good condition with only hairline crack starting
Space saver spare wheel
Oil pressure/boost pressure/voltage gauge panel
Fog lights/rear screen heater switch panel
Digital clock - provisionally sold
MOMO steering wheel (not Volvo one)
Door handle/speaker covers
side repeaters
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
jamesy12345
Post
by jamesy12345 » Sun May 22, 2016 6:37 am
Surprisingly I'll probably owning a 400-series again shortly...so now only the following items are available until I work out what is good/not good on the new car
side repeaters
not much left really, if no-one takes them say 3 weeks from now I'll be donating all parts to the local scrappy or similar
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
doingitsideways
Post
by doingitsideways » Sun May 22, 2016 10:00 am
jamesy12345 wrote:Surprisingly I'll probably owning a 400-series again
Surprising?
Who you trying to kid??
jamesy12345
Post
by jamesy12345 » Sun May 22, 2016 10:11 am
doingitsideways wrote:jamesy12345 wrote:Surprisingly I'll probably owning a 400-series again
Surprising?
aye it seems like I'm a repeat offender
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
cranna21
Post
by cranna21 » Fri May 27, 2016 7:52 am
hi mate, have you got any of the brakes left? also is it ABS or non ABS ? looking to upgrade my ES to vented fronts, all i really want/need are the front carriers as new calipers are not that badly priced
cheers!
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
jamesy12345
Post
by jamesy12345 » Fri May 27, 2016 10:43 pm
cranna21 wrote:hi mate, have you got any of the brakes left? also is it ABS or non ABS ? looking to upgrade my ES to vented fronts, all i really want/need are the front carriers as new calipers are not that badly priced
cheers!
nothing left mate other than that short list above, sorry
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
jamesy12345
Post
by jamesy12345 » Sun Jun 05, 2016 4:28 pm
Photos of boot/fuel lid release cover for dcwalker
Ends of bolt hole sleeves are damaged but not visible from outside
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Post
by dcwalker » Mon Jun 06, 2016 8:29 am
Thanks for going to that effort James.
TBH that one's much the same as the one I have, so I'll leave it I think...thanks anyway!
All the best
jamesy12345
Post
by jamesy12345 » Mon Jun 06, 2016 9:33 am
dcwalker wrote:Thanks for going to that effort James.
All the best
no worries at all David, cheers
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
SamH
Post
by SamH » Thu Jul 14, 2016 8:53 am
Hi Jamesy,
Do you still have the dashboard surround available please?
Sam
jamesy12345
Post
by jamesy12345 » Tue Jul 19, 2016 2:58 pm
I will check Sam it might have gone already
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
jamesy12345
Post
by jamesy12345 » Thu Oct 27, 2016 8:15 am
jamesy12345 wrote:I will check Sam it might have gone already
Forgot about this - I still have it if you want it Sam...!
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
