Hi, I have a GT with the usual duff speedo, which worked but now decided to stop. Has anyone a speed sensor for it, or know anyone with some spares. I have looked on wanted etc....no luck
Thanks Al
Speedo sensor desperately wanted. MOT coming up
480 GT Green Aug 1994 "Sven"
480 Turbo Robou Paris Blue Aug 1992 "Eva"
SAAB 9-5 HOT Aero estate 2008 Black "Kemosaaby".........weasel xxxx comes to mind.
Previous cars.
940 2.3 SE Turbo May 1995 Burgundy "The Spy"
850 SE 2.5 1996 Burgundy. "Mew"
940 2.0 White "Dexy"
Previous cars.
Re: Speedo sensor desperately wanted. MOT coming up
Are you SURE it's the speedo sensor? Most of the speedo problems are caused by faulty connections on the instrument cluster PCB. Proper soldering of the connector pins usually does the trick.
See also this, very recent topic: http://www.volvo-480-europe.org/forum/v ... 12&t=34885
Also, you could try and clean the speedo sensor connector in the engine bay, and the sensor itself of course. These things have no active electronics, it's just an electromagnetic pick-up, they can only go wrong by mechanical wear caused by the gearbox oil that's thrown at them.
I could check and (if necessary) repair the cluster for you for the cost of postage and a few beers, but I'm not in the UK.
No Brinkie. In my case everything was fine with the instruments board. It was the speedo sensor all the way.
I read GlasgowJim once that he would change speedo sensor first and move from there if things didn't solve. I wish I would have gone that way.
Gremlins? I swear I didn't feed the car after 12 pm,but I got Gremlins, Creeters, Jason, Freddy and the damn Chucky.
BTW the only way to get a speed sensor is trying scrapyard. Shared by all 400 series number 3413744 till the end of 1992 and 3467846 from there. Don't know chassis number break.
1991 480 Black Turbo
2012 Seat Exeo ST
2013 VW Polo TSI DSG
2012 Seat Exeo ST
