clips & small bits!
clips & small bits!
Im after the clips that hold on the black trim in front of the rear window & the water jet nozzle for the front windscreen washers. Oh and a handfull if trim clips for the runners that hold on the trim under the front door. Small stuff but would be much appreciated!
Tim
Tim
Re: clips & small bits!
Hi tim
can supply a a handful of trim clips and odds and sods of various trim clips for the cost of the postage + £1
I dont have any washer parts (jets) though.
let me know what you want to do ( I reckon the postage is about £2.00 )
That sounds great Jim, do you have the clip that holds on the black trim in front of the rear window? Im really keen to eliminate that from the foot-well flood investigation
Thanks again
Tim
Thanks again
Tim
Not too sure what part you are referring to can you be more specific?
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Hi Jim, sorry yes, you know the bit of plastic trim that is between the rear window and the front window. On Turbo cars the bit of trim says "Turbo" on it, but on 1.7's and 2.0's it says nothing Anyhow, its held onto the body of the car by two little whiteish clips which slide into runners in the trim- kind of the opposite side of the seat-belt mechanism on the interior. Im after at least one of those clips
Have to say though, 50ml of tolleys crack cure later the captain may have come good for me again! I think the Celebration flood may be over!
Hope that helps, Im still interested in some of these if you have them.
Best
Tim
Best
Tim
Hi tim I do know what you are speaking of should have some of those. Will need to get back to you later in the week.
regards jim
regards jim
No hurry Jim
T
T
Hi tim have looked out 4 white exterior panel clips that you asked for + 3 of the clips that hold the under side of the door panel to the door. you have a pm
