small shoping list
- joe480reed
small shoping list
I know it's a long shot but looking for richmod or robou ecu mod , 16 inch wheels any considered as long as they fit or a set of tarus think that's what there called , head light switch and a roller boot cover!! asking a lot I know oh and any advice on 20 mm lowering springs be great to
Re: small shoping list
I think Robou still mods ECU's. Can't be sure though. Maybe send him a PM.
All stock alloys were either 14" or 15". I'm looking to the future with 16" Borbet A's.
And the 40mm springs will lower a Turbo 20mm. Turbo's are supposedly 20mm lower than the rest of the range.
You'd probably need an adjustable Panhard rod though or the rear axle would be pushed over to one side.
- joe480reed
Yer been looking at the borbets myself they always seem to be bigger rears
do you mean the round switch for the headlamps. If so I have a spare available.should also have a roller boot cover as well need to check.
- joe480reed
Yer that's one Jim is it in good nic as in are the pictures worn off?
The borbets come in 2 sizes. 16x7.5 or 16x9. BMW owners put the 16x9's on the back and the 16x7.5's on the front but if you buy new you can order any combo of the sizes you want lol.
A set of the 16x7.5's should fit all round and with tyres that allow for the rolling radius even the speedo will be correct.
