WANTED : turbo fuel injectors
r5b18ft
Post by r5b18ft » Wed Feb 06, 2013 12:16 pm
Already through my second set of injectors :cry: They're getting stuck from storage (don't really use the car much).. tried to take them for ultrasonic cleaning and one of them is still stuck and the guy told me that the others aren't that good either.
SOOO... I'm needing a set of GOOD turbo (B18FT) injectors
If they're being taken off a stored engine (with chances of fuel remaining in the fuel rail, even a small quantity) then they're probably no good as they're stuck. Apparently the fuel dries out and leaves a sediment which jams the injectors. The guy said it happens to many cars and said that they must run at least once a month for this not to happen. Mine got stuck from 2 months of storage.
jamesy12345
Re: WANTED : turbo fuel injectors
Post by jamesy12345 » Wed Feb 20, 2013 6:19 am
Hi, just noticed this post. I have some injectors but yes there are fitted to a car that gets used hardly at all. Also it's a 1991 turbo
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
jamesy12345
Post by jamesy12345 » Wed Feb 20, 2013 6:26 am
is this yours?
http://www.renault5gtturbo.com/forum/vi ... f=2&t=8037
if so, or even if not, niice
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
r5b18ft
Post by r5b18ft » Fri Feb 22, 2013 4:56 pm
jamesy12345 wrote:is this yours?
Yes that's mine, thanks :D
