Wanted - instrument cluster
Hi all
It's been a long while since I posted on here...
The odometer and trip meter on my 480 Celebration have stopped working. Speedometer and info centre are all working fine, so I presume speed sensor is OK and still sending its signal; I have been right along the wiring; all connections to instrument cluster are good, clean and tight - so I can only assume it is the toothgear has worn or something like that.
So, please does anyone have a working spare instrument cluster they'd like to sell? Must be compatible with 1995 2 litre (B20F), 60 litre fuel tank, green and grey connectors...
Hoping someone can help!
Re: Wanted - instrument cluster
You only need a replacement speedometer either that or you can replace the gear wheels , a forum member manufactures these. will try and look out the relevent htread.
Thanks for the advice Jim - do you happen to have a speedometer among your stores?
check on page 2 of this thread regarding speedo cogwheel replacements.
http://www.volvo-480-europe.org/forum/v ... 03#p198003
yes I also have a replacement speedometer what is your current mileage ?
Hi Jim
Thanks for the heads-up about the cog. I like to think I am quite competent mechanically, and have had the speedo out of the instrument panel to check it over, but I am a bit wary of starting trying to replace cogs....
My mileage is 128,900 - and I would be very interested in a replacement speedo! I have sent you a PM.
Many thanks
Many thanks
David you have a pm
Thanks - replied!
Problem solved - many thanks, Jim!
