Glasgowjim's spares list
I have been asked by several forum members if I could list the spares I have ...
I have put this in the sales part of the forum although this is not a parts for sale list . I reiterate that I am not a dealer/breaker just another enthusiast who has happened to build up a store of spare parts. But if it saves forum members having to spend ages searching the internet to locate a part to keep their 480 on the road then this post will have served its purpose.
So here goes for the main parts :-
UPDATED 10/10/14
Now breaking an M reg 480 in white
(rear light units unavailable).
UPDATED 31/12/14
XXXXXXXXNew additions to spares list (22.3/14) XXXXXXXXXX
pair of unbroken door pockets
window regulators
Lamp controller
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
4 rear seat belts
1 under engine plastic covers
1 large bag of assorted wiring partial looms connectors etc.
1 large bag of assorted rubber seals , hoses etc
1 heater assembly
1 rh front wheel arch protectors
1 lh front wheel arch protector
4 plastic rear suspension stoppers/bumper stop
4 outer upper top side trim (for above rear windows) 2 paris blue
4 rear hatches
1 main exhuats for 92 1.7ltr with cat (new)
3 radiator fans
3 cabin/heater fans
1 bonnet
4 rear hatch struts
5 pairs of rear side windows
7 front door windows (3 pair + 1 single)
4 near side quarter light windows
5 off side quarter light windows
5 power steering pumps
1 red dip stick
1 green dipstick
2 screen washer tanks
2 brake servo units with relay
2 power steering racks
1 rear anti roll bar
1 pair of drive shafts
2 gear selector rods
2 cats (2ltr)
1 M60E gearbox
4 radiators
3 heater matrices
1 complete 2 ltr inter cooler to downpipe connector
2 2ltr intercoolers +throttle bodies
2 complete wiper assemblies +motor
1 wiper motor only
7 92 onwards front engine mounts (newstyle)
1 post 92 rear engine mounts
2 post 92 rear engine mount frame
1 alternator mounting frame
4 clutch cables (later models)
4 accelerator cables (late model)
4 interior roof lights
LHS long range driving lights
2 pr rear bulb holders
2 battery earth straps
ignition units and capacitor for non turbos.
5 bonnet hinges
1 red plastic tub of various lock mechanisms
3 complete gear levers
4 horns
2 moonroofs
5 idle control valves
1 complete dash board with loom
multiple all interior trim except the plastic housing surrounding the petrol tank-rear hatch lever
multiple vents
abs controller MK2
front headlamps
analogue clocks
alarm led
2 heater slider units
2 doors (pair)
triple bank of light switches
multiple rotary switches
multiple instrument pod bulbs
4 rev counters
4 starter motors (1 new)
1 MBC (new and unused)
1 k&N type air filter
2 air filter boxes
several selector switches for info centre
multiple stalks - wiper
4 water pumps
water washer pumps large and small
all small plastic trim pieces
SRS controller
Airbag
Airbag + steering wheel
airbag yoke
spare airbag "spring" assembly
umpteen rear light holders
petrol flaps
petrol flap spring loaded catch with and without the connecting wiring
bonnet latches
front internal black plastic "hood" for radiator
2 new ball joints
2 servo brake unit
pedal assembly
2 spare roof linings with moonroof aperture
2 rear roller boot covers
oh and heater resistor unit as well.
every bolt nut and screw ever put into a 480
plus umpteen other parts too numerous to mention.
way too much stored in shed and garage
UPDATED 10/10/14
UPDATED 31/12/14
window regulators
Lamp controller
4 rear seat belts
1 heater assembly
4 rear hatches
3 radiator fans
3 cabin/heater fans
1 bonnet
4 rear hatch struts
1 red dip stick
1 green dipstick
2 cats (2ltr)
1 M60E gearbox
4 radiators
3 heater matrices
1 wiper motor only
5 bonnet hinges
4 horns
2 moonroofs
multiple vents
abs controller MK2
front headlamps
analogue clocks
alarm led
2 doors (pair)
4 rev counters
2 air filter boxes
4 water pumps
SRS controller
Airbag
airbag yoke
petrol flaps
bonnet latches
2 new ball joints
2 servo brake unit
pedal assembly
Re: Glasgowjim's spares list
if you dont believe me...
and its got fuller since these photos were taken....
I love it , yo the best
Hi
Looking for : door pocket , r.h / your driver side / , front fog lamp r.h , year 1995 All in very good condition .
regards
Marek
regards
Marek
Hey, how much for the roller boot cover, preferable with the fittings. Cheers
you have a pm.
Jim
which ' Ball Joints'?
do you happen to have the 'drop links' for front anti-roll-bar
I need to check which side tho cos they are handed (I think). (front OFF SIDE)
any idea of the model the SRS controller came from?
I think that they are different for different years/models? mine is a Sept 1993 TWO litre with SPRING seat-belt tensioners
Hi Alan
the balljoints are for the front suspension arms and are the lower balljoint that attaches the front suspension arm to the wheel and suspension assembly. The balljoints I have are brand new.
Will check on the srs unit and pm you with year if possible.
I should have drop links for the front it is a matter of finding them in the shed
I dont think they are sided but will check for you.
regards jim.
regards jim.
Jim
OK I will check in case the bottom ball joints are 'year' or 'model' dependant, which I doubt
The SRS light has taken a habit of flashing on at random times and not sure whether to bother fixing it, the previouscars only had FIXED seat-belts!
air bags are if you don't wear a belt??
Alan you are correct there are 2 versions of the srs control unit . I have spares of both
The top of the unit has a large label and printed on it is the volvo part number it is either
471388 or 474128
£35 includes uk postage first class for either unit.
regards jim.
471388 or 474128
regards jim.
what about me ?
Hi Marek
sorry do not have an intact front foglamp but can supply a replacement glass lens and you can just glue it in position .
still to check on the door pocket. Away to do that now.
regards jim.
regards jim.
Sorry Jim , I need a whole fog lamp , waiting for door pocket
regards
Marek
regards
Marek
sorry Marek only have the UK passenger side ( left hand side ) door pocket.
regards jim
regards jim
How much incl . Post to Poland ?glasgowjim wrote:sorry Marek only have the UK passenger side ( left hand side ) door pocket.
regards jim
Hi Marek you have a pm
picture please ?glasgowjim wrote:Hi Marek you have a pm
Hi Marek will post photo later tonight just in from work .
Thanks , looking also for 3rd brakelight plastic casing
Hey Jim,
Hope all is well with you and the fleet.
Can you advise if you have any 'spare' front foglights at all? I'm led to believe these should fit the apertures on the front of my Mk1 440, but tracking some down is proving difficult (as usual).
Thanks again
Roge1
Thanks again
Roge1
