WANTED: 480 1.7 Turbo Manual Gearbox
Hello
I have just bought a 19889 480 1.7Turbo and the gearbox has disintegrated, im looking for a replacement box or a donor car. anyone out there who can help???
Cheers Richard
Cheers Richard
Re: WANTED: 480 1.7 Turbo Manual Gearbox
would help if people knew roughly what part of the world you are located
Very good point! Im in Leicester, England.
have a 2l engine and gear box free to collect perfect gear box not sure if the box is the same as a 1.7
- bigdickbuster
Basically gearboxes are the same in all model of 480. But they are differences in strength of the materials used to the build of this element. M52 are the weakest gearbox. M59 are the strongest.
Regards, Adrian
Regards, Adrian
ex 1990 480 TURBO, model year '90, 231 Red This car was a mistake
Ok so basically it should fit ok then, where abouts are you located?
be careful about the size of flywheel as there are 2 different sizes.
BUMP! Anyone out there that can help?
